17497 Discussions
Help Identifying CPU package
dr92060
Picked this up used, believing it to be socket 1151 coffee lake. I have not been able to identify it yet. Take note of number one pin and install alignment cuts. I have not seen this set up at all. Any help would be appreciatedd. Just acll me confused. Thanks. 20251114_081028[1].jpg20251114_081028[1].jpg20251114_081054[1].jpg20251114_081054[1].jpg
dr92060
Quick update thanks for the replies. Turns out after some searching, it is a counterfeit cpu. Someone changed out the heat spreader. Lucky me.
AlHill
If it is an SRG10, then it is an i5-9500F.  Your image was not very clear.
Note that it does not have graphics.
Also note that it is a  tray processor, meaning you have no warranty.
https://www.intel.com/content/www/us/en/products/sku/190890/intel-core-i59500f-processor-9m-cache-up-to-4-40-ghz/specifications.html
And, it is a LGA1151 socketed processor.
[CoPilot is a virus]
n_scott_pearson
No, it's SRG19, a Core i9-9900K. This means it *does* have iGFX.
AlHill
Then this is your processor:
https://www.intel.com/content/www/us/en/products/sku/186605/intel-core-i99900k-processor-16m-cache-up-to-5-00-ghz/specifications.html?wapkw=i9-9900K
Sorry, eye treatment this morning and cannot see all that well.
dr92060
Thank you for the reply. It is supposed to be an I9 9900K srg19. I thought the images were clear when I uploaded. My problem is I am not finding I9 9900k srg19 that are set up anything like this, It will not fit in the lga 1151 socket on this board. If you note where the number one pin is and the lay out of the pins, it is different than others I have seen, and I have seen none like this. If you need better pics please let me know. If you compare it physically to others, you should see what I mean. Something just seems off. I am going to return but i would like to know just what the difference is, and why it's different. I appreciate your time.
dr92060
n_scott_pearson
I am sorry to have to tell you that you've been scammed. That's a LGA775 package. This processor has been remarked to look like a Core i9-9900K when, in fact, it is an absolutely ancient (Core 2 Duo/Quad/Extreme, Pentium 4/D/Dual-Core, or Celeron) Processor.
I hope you bought it through a storefront through which you can get your money back.
dr92060
Thanks for the reply. It took me some searching but I figured that out. I guess you have to watch everythingg anymore. Should be able to get refund, fingers crossed.
