16841 Discussions
Help needed with E5300 and E5xxx processors
Hi, i need a help and i need it quick will any processor from E5xxx series will work with my Asus P5LD2-VM motherboard ? will it need any BIOS updates or something. If not, could you reccomend a cheap motherboard that will work with this processor?
From the Asus Website, it seems that the board does not support any E5xxx family cpu.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
If you are looking for compatible intel boards that work with E5300 or E5xxx cpu family. Check it from the link below.
Make sure to check the bios update required for it to work fine
http://processormatch.intel.com/COMPDB/default.aspx
All the best,
Aryan
