16773 Discussions
High idle temps for Core Ultra 155H
DeathAndNoTaxes
Bought a "Refurbished Good" Vivobook laptop a few months ago. Checked everything about the laptop and all was fine, just the advertised cosmetic damage. Today, my curiosity piqued and I knew that Intel Meteor Lake CPUs run fairly hot, but I actually never checked my own laptop. My laptop was basically idling for an hour around 10% usage, and the temperature on the MyASUS app showed around 80 C. My ambient room temperature is 27 C. Chatgpt said the CPU temp should be 35-50C. The fans look reasonably clean, and the fans run on Standard Mode which should be fine for an idling CPU.
Maybe the thermal paste is bad? Should i use another software to monitor?
pressed_for_time
Valued Contributor II
Higher than expected idle temperatures on laptops can be caused by background processes such as file indexers. Might be worth seeing if Task Manager is showing anything.
DeathAndNoTaxes
The temperatures have cooled this morning. I ran the laptop on battery and turned on energy saver and turn fans to Whisper mode, started streaming some 4K60 video. CPU usage 9% and the CPU temperature was only 50C. Temps did rise when I turned off Energy saver and plugged in the laptop. My default power mode is "Performance mode" when plugged in. Kept streaming the video, E-core temps were stable around 70-75C while P-core temps fluctuated between 70-90C. I'm using HWiNFO.
