16803 Обсуждение
High temperature i7-14700KF at idle (no load)
STARKSTRIM
Начинающий
14 106Просмотр.
Processor i7-14700KF paired with good water cooling Li Galahad 2 Trinity at idle about 45 degrees (browser and a couple of programs, while the cooler runs +- 1000 rpm). In games it's about 70-80 degrees. In stress tests 90-95 degrees. Is there something wrong with the stone? 🤷‍♂ The case is open, there are many coolers. ROG STRIX Z790-A GAMING WIFI II motherboard, video card ASUS PCI-Ex GeForce RTX 4080 ROG Strix, MSI MPG 1000W power supply. I would be grateful for any hint or advice on what to try.
0 баллов
8 Ответы
Jocelyn_Intel
Сотрудник
14 071Просмотр.
Hello, @STARKSTRIM
Thank you for posting on the Intel® communities.
I understand your concern about the processor temperatures.
However, those idle and workload temperatures are expected and normal values, the processor can go up to 100°C degrees per its specifications. Also, it is expected behavior that the processor has higher temperatures while running workloads, like games or stress tests, as these put the processor under heavy cycles or processes.
This is specified in this article: Seeing Temperature Spikes when Playing Games on Systems with Intel® Core™ Processors
Are you having crashes or any other performance issues due to these temperatures?
Jocelyn M.
STARKSTRIM
Начинающий
14 028Просмотр.
I'm interested in the temperature not under load, isn't it too high when paired with a good 3-section dropsy?
Jocelyn_Intel
Сотрудник
14 030Просмотр.
Hello, @STARKSTRIM
I hope you are great.
I am checking this thread and I would like to know if you still need help.
Jocelyn M.
STARKSTRIM
Начинающий
14 020Просмотр.
I didn’t even notice that I attached the wrong screenshot, I apologize) I attached the right one
STARKSTRIM
Начинающий
14 019Просмотр.
Maybe something is wrong with the voltage, with the power supply, so the processor gets hot?
STARKSTRIM
Начинающий
14 018Просмотр.
cooling and airflow are ok, coolers operate at an average of 700 rpm
Jocelyn_Intel
Сотрудник
13 902Просмотр.
Hello, @STARKSTRIM
Thank you for your reply and the information provided.
Those are expected and normal temperatures, the processor can go up to 100°C degrees per its specifications. Intel processors constantly monitor their temperature and can rapidly adjust their frequency and power consumption to prevent overheating and damage. This is specified in the article Seeing Temperature Spikes when Playing Games on Systems with Intel® Core™ Processors
What is exactly bothering you? Do you have BSODs or any other performance issues?
We can test the processor with official Intel tools, but the processor is not overheating if that data is accurate.
Jocelyn M.
Jocelyn_Intel
Сотрудник
13 846Просмотр.
Hello, @STARKSTRIM
I hope you are doing great.
As we have not heard back from you, we will proceed to close this thread now.
If you need any further assistance, please feel free to contact us back and submit a new question as this thread will no longer be monitored.
Jocelyn M.
Ответить
