17152 Discussions
How can I boost Intel Pentium N3700 to 2.4Hz?
I need you help, because I didn't find how to turn on turbo boost on my processor.
AlHill
My standard answer would be to check to see if turbo boost was enabled in the bios.
However, I checked the specs on the N3700, and the specs say it does not have turbo boost:
http://ark.intel.com/products/87261/Intel-Pentium-Processor-N3700-2M-Cache-up-to-2_40-GHz Intel® Pentium® Processor N3700 (2M Cache, up to 2.40 GHz) Specifications
In fact, none of the n3000 series seem to have turbo boost:
http://ark.intel.com/products/series/76756/Intel-Pentium-Processor-N3000-Series-for-Mobile# @Mobile Intel® Pentium® Processor N3000 Series for Mobile
The Intel support staff will have to confirm.
In the meantime, I did find this: http://www.intel.com/content/www/us/en/support/processors/000005647.html Intel® Turbo Boost Technology Works - What It Is and How It Works
Sorry I could help more.
Doc
AlHill
Doc
Okay, thanks.
So is here any chance to reache 2.4Hz on this processor? Because now I'm on 1.6Hz.
AlHill
If the processor does have turbo boost, and it is enabled, you would do nothing. The processor will give you the performance when needed.
I looked at the specs again. While they say there is no turbo boost, they also say the base frequency is 1.6ghz and burst frequency is 2,4ghz. So, we will have to have the Intel support staff confirm.
Doc
Hello, All:
DavidJanoska, please refer to Al_Hill previous inputs, he provided the correct answer. The Burst frequency of your processor is intended to provide on-demand, higher performance for very short intervals of time in small device form factors, from the BIOS there is no option to enable it.
See here for more information in regard to the Intel® Turbo Boost Technology http://www.intel.com/content/www/us/en/support/processors/000005641.html Frequently Asked Questions about Intel® Turbo Boost Technology.
Amy.
