16791 Discussions
Heatsink Fan doesn't Spin Properly
AAudi3
So I've just installed a new processor i5-6600 with ASRock H170 Fatal1ty Performance. Then, I plug the heatsink fan power into CPU_FAN_1. When I turn the power on, it doesn't spin properly like this: http://youtu.be/KvxxJmTLngk Faulty stock Intel i5-3570K CPU heatsink fan - Tiny spin every second or so - YouTube (credit to the owner of the video).
Then, I try to plug it into CPU_FAN_2 (header number 2), and it spin yet has delay 2 seconds after I turn the power off. (So after I turn the power on, there is 2 seconds delay before the fan starts to spin).
So, is my heatsink fan faulty? Or is it the motherboard?
Hello, Auday:
Is there any chance you can test your motherboard with the minimum configuration? Try removing all the peripherals and just test one RAM stick.
Amy.
Hello, /thread/105431 Auday:
I am following up your thread.
Were you able to follow the suggestion mentioned above? Do you still require assistance?
Amy.
AAudi3
Hi Amy, sorry for the delay.
So last week, I went to the store and I need the motherboard to be replaced. Yet, the same problem happened with brand new motherboard with same type.
I assume it's the heatsink fan compatibility with the motherboard. Too bad I didn't check it with other type of motherboard or heatsink.
So right now, I'm using a third party heatsink from CM and plug it to my cpu_header_2
ssote
New Contributor II
How is it working now? to bad I did not see this thread before I have a new Intel heatsink fan I can sell you.
How it the third party heat sink working? Do you see any difference?
Amy.
