16929 Discussions
How do I disable Intel Extreme Tuning Utility's Turbo Boost Short Power Max Enable?
Nyse
My "Turbo Boost Power Max" setting is set at 45.000 W but I want it at 10.000 W. When I reduce it to the wanted 10.000 W, the program very quickly resets it at 45.000 W. How would I go about solving this issue?
I tried disabling it all together, but the program enables the feature in question on it's own as well.
VARADHARAJAN
Valued Contributor II
intel extreme tuning utility will install on all most intel based windows computer , but for configuring tuning work , only intel few processors are supported
here is the supported
  • Intel® Core™ i3-7350K Processor (4M Cache, 4.20 GHz)
  • Intel® Core™ i3-8350K Processor (8M Cache, 4.00 GHz)
  • Intel® Core™ i5-4670K Processor (6M Cache, up to 3.80 GHz)
  • Intel® Core™ i5-4690K Processor (6M Cache, up to 3.90 GHz)
  • Intel® Core™ i5-6600K Processor (6M Cache, up to 3.90 GHz)
  • Intel® Core™ i5-7600K Processor (6M Cache, up to 4.20 GHz)
  • Intel® Core™ i5-7640X X-series Processor (6M Cache, up to 4.20 GHz)
  • Intel® Core™ i5-8600K Processor (9M Cache, up to 4.30 GHz)
  • Intel® Core™ i7-3920XM Processor Extreme Edition (8M Cache, up to 3.80 GHz)
  • Intel® Core™ i7-3930K Processor (12M Cache, up to 3.80 GHz)
  • Intel® Core™ i7-3940XM Processor Extreme Edition (8M Cache, up to 3.90 GHz)
  • Intel® Core™ i7-3960X Processor Extreme Edition (15M Cache, up to 3.90 GHz)
  • Intel® Core™ i7-3970X Processor Extreme Edition (15M Cache, up to 4.00 GHz)
  • Intel® Core™ i7-4770K Processor (8M Cache, up to 3.90 GHz)
  • Intel® Core™ i7-4790K Processor (8M Cache, up to 4.40 GHz)
  • Intel® Core™ i7-4820K Processor (10M Cache, up to 3.90 GHz)
  • Intel® Core™ i7-4930K Processor (12M Cache, up to 3.90 GHz)
  • Intel® Core™ i7-4930MX Processor Extreme Edition (8M Cache, up to 3.90 GHz)
  • Intel® Core™ i7-4940MX Processor Extreme Edition (8M Cache, up to 4.00 GHz)
  • Intel® Core™ i7-4960X Processor Extreme Edition (15M Cache, up to 4.00 GHz)
  • Intel® Core™ i7-5820K Processor (15M Cache, up to 3.60 GHz)
  • Intel® Core™ i7-5930K Processor (15M Cache, up to 3.70 GHz)
  • Intel® Core™ i7-5960X Processor Extreme Edition (20M Cache, up to 3.50 GHz)
  • Intel® Core™ i7-6700K Processor (8M Cache, up to 4.20 GHz)
  • Intel® Core™ i7-6800K Processor (15M Cache, up to 3.60 GHz)
  • Intel® Core™ i7-6820HK Processor (8M Cache, up to 3.60 GHz)
  • Intel® Core™ i7-6850K Processor (15M Cache, up to 3.80 GHz)
  • Intel® Core™ i7-6900K Processor (20M Cache, up to 3.70 GHz)
  • Intel® Core™ i7-6950X Processor Extreme Edition (25M Cache, up to 3.50 GHz)
  • Intel® Core™ i7-7700K Processor (8M Cache, up to 4.50 GHz)
  • Intel® Core™ i7-7740X X-series Processor (8M Cache, up to 4.50 GHz)
  • Intel® Core™ i7-7800X X-series Processor (8.25M Cache, up to 4.00 GHz)
  • Intel® Core™ i7-7820HK Processor (8M Cache, up to 3.90 GHz)
  • Intel® Core™ i7-7820X X-series Processor (11M Cache, up to 4.30 GHz)
  • Intel® Core™ i7-8086K Processor (12M Cache, up to 5.00 GHz)
  • Intel® Core™ i7-8700K Processor (12M Cache, up to 4.70 GHz)
  • Intel® Core™ i9-7900X X-series Processor (13.75M Cache, up to 4.30 GHz)
  • Intel® Core™ i9-7920X X-series Processor (16.5M Cache, up to 4.30 GHz)
  • Intel® Core™ i9-7940X X-series Processor (19.25M Cache, up to 4.30 GHz)
  • Intel® Core™ i9-7960X X-series Processor (22M Cache, up to 4.20 GHz)
  • Intel® Core™ i9-7980XE Extreme Edition Processor (24.75M Cache, up to 4.20 GHz)
  • Intel® Core™ i9-8950HK Processor (12M Cache, up to 4.80 GHz)
for more information visit below intel site
https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU-
Nyse
Before just recently I could change the settings trough the Intel Extreme Tuning Utility program and it would remember by preferences. Now it doesn't. Why?
Wanner_G_Intel
Hello Nyse, We would like to continue assisting you. Could you please confirm your system configuration? Please run the Intel® System Support Utility and attach the report to this thread. 1.Download the Intel® System Support Utility and save the application to your system. https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600 2.Open the application and click Scan to see system and device information. The Intel® System Support Utility defaults to the Summary View on the output screen following the scan. Click the menu where it says summary to change to Detailed View. 3.To save your scan, click Next and click Save. You can save the file to any accessible location on your computer. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
Wanner_G_Intel
Hello Nyse, If you are still having the issue reported, please attach the report requested or provide us with your processor number. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
