16970 Discussions
How do I verify Quick Sync is working?
BBarr8
I have been trying HandBrake and MCEBuddy, and they don't see my system as having Quick Sync enabled. I have the 64-bit version 15.36.7.64.3960 (10.18.10.3960) drivers installed. Is there a way I can verify that Quick Sync is properly setup?
Here is my setup:
  • ASUS Maximus VI GENE | ASUS GTX 760
  • Intel i7 4770 | 16GB G.SKILL Ripjaws X Series DDR3 2400
  • Intel 235 240GB SSD
  • Intel HD Graphics 4600 (nothing plugged into it)
Silvia_L_Intel1
Bibbit, I'm sorry for the inconvenience I replied to the incorrect thread.
Regarding your issue would you please run a DxDiag on your system and once it finish please search for Quick Sync.
(Start -> Run -> dxdiag -> Save All Information)
Let me know the results.
Silvia L
BBarr8
I was able to get Quick Sync working. It took me some time to figure it out (BIOS changes and such), but it is now working.
Thanks!
___Bibbit
Silvia_L_Intel1
Would you please share with us how you got QuickSync working so we can help future customers?
BBarr8
I turned on the onboard GPU in the BIOS, and then installed the latest video drivers for my CPU's GPU. Then after booting I let the system create a faux monitor for a third monitor, with that monitor being connected to the Intel GPU. The faux monitor shows up as non-PnP monitor. It doesn't work with the faux monitor disabled.
After that I made certain that Quick Sync was enabled in the software I was running and that I used the Quick Sync encoder codec. My transcoding frame-rate went from 20 FPS with 100% CPU to 250+ FPS with 60% CPU. The time went from 2.5 hours to 15 minutes!
Silvia_L_Intel1
Thanks alot for the information Bibbit.
