16800 Discussions
How does the PC keep writing logs in XTU when I have no XTU installed?
LenD
As the title says I recently threw away 17GB of logs from a programm "Intel Extreme Tuning Utility"
I do not have such a programm installed on my PC yet it kept writing logs. After searching through this forum I installed it just to check if I can uncheck "Enable Telemetry Data Collection" in the settings, but I could not find any setting like that in the current version under the advanced options tab.
After I uninstalled the programm again it still writes a log file after each restart. However the only thing that gets noted is this:
"2019/08/19-09:55:08.7379|!ERR] System info connection was null
2019/08/19-09:55:13.7451|!ERR] System info connection was null
2019/08/19-09:55:13.7451|!ERR] System info connection was null" and so forth.
How can I disable the program from writing logs all together and is it linked to some other program I might have installed? Asus AI Suite maybe?
AlHill
What is the model number of your laptop or motherboard?
What is the processor model number?
What operating system? Windows 10? What version? 1903?
Doc
LenD
Hey,
here are some more Infos:
CPU is an overclocked i7 6700k running on 4.5Ghz
Windows 10 Pro
Version 1903
Build: 18362.295
Motherboard is Asus Maximus VIII Hero
16GB RAM
Hope this helps
David_V_Intel
Hello LenD,
Thank you for posting on the Intel ® communities.
In order to Uninstall Intel® XTU please access Apps in the settings, search for it and uninstall it.
Also, the following:
- Delete any folder named Intel® XTU from these locations: "C:\Program Files (x86)\Intel", "C:\ProgramData\Intel".
- Delete the folder named "Intel® Intel Telemetry" under “C:\ProgramData:”.
I hope this helps.
David V
A Contingent Worker at Intel
LenD
Hey David thanks for the response,
I did find a "XTU.msi" under programs, after uninstalling it I was able to delete the logs folder briefly.
After a restart the pc writes those logs again. I cannot find any program installed related to that software/datapath.
As shown in the pictures these are all the running intel programs in my task manager and the searches for the program itself.
Intel_02.pngIntel_03.pngWhen I open the mentioned application path those are the files I see.Intel_04.png
And if I try to delete the folder as proposed I get an error message saying the folder/Datas in the folder is/are currently in use.
Where can I access this program and can I get rid of it. Over the years this program produced so much datawaste.
David_V_Intel
Hello LenD,
Thank you for your response.
I was checking your motherboard manufacturer's website and I was able to find an Intel ® Extreme Tuning Utility version Asus*-specific. Please download this version, try disabling the "Enable Telemetry Data Collection"(while Intel® XTU is running, go to settings in the upper right corner > "Advanced Options" tab) to see if the logs still affect it.
Refer to the link below:
https://www.asus.com/Motherboards/MAXIMUS-VIII-HERO/HelpDesk_Download/
* Please be aware that the content on that site is not controlled by Intel*. This information is offered for your convenience and should not be viewed as an endorsement by Intel* for the merchants or services offered there. *
I hope this helps.
David V
David_V_Intel
Hello LenD,
Were you able to check my previous suggestion?
Please let me know if this worked for you.
David V
David_V_Intel
Hello LenD,
Please contact us back if you need more assistance.
David V
