I have the 10920x OC’d to 4.1GHz when all cores are utilized, and it reaches around 70C under full load. Should I be worried about this chip sitting at 80C if I want to push these numbers higher?
Hello DHopk8
Thank you for posting in the Intel Community.
The Intel® Core™ i9-10920X X-series Processor can reach 94°C (that is its T-junction), the temperature that you are reporting are still within the specification.
I would like to share with you the Intel® Performance Maximizer that is a overclocking tool that can be used in you Intel® processor.
You can find more details about the Intel® Performance Maximizer in Frequently Asked Questions for the Intel® Performance Maximizer.
If you are going to use the Intel® processor with overclocking, we recommend using the Intel® Performance Tuning Protection Plan to protect the unit’s warranty.
NOTE: Altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components, and may reduce system stability and performance. Product warranties may not apply if the processor is operated beyond its specifications.
Leonardo C.
No, these short duration loads shouldn't damage the processor. If you were holding the processor at these temperatures for hours at a time, I would be more concerned, however.
80c is perfectly safe for these short durations. Long (and worrisome) durations are hours in length. In that case, I would also be worried about the heat from the processor possible disdaffecting other components on the motherboard as well.
Hello DHopk8
The operating voltage for the Intel® Core™ i9-10920X X-series Processor is 1.83, it is important taking into consideration that the motherboard provides the voltage to the Intel® processor.
Leonardo C.
Hello DHopk8
Was the information provided useful for your request?
Leonardo C.
Hello DHopk8
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Leonardo C.
