17147 Discussions
How much ram memory does an intel i3 2100 support per slot?
Vx1
What is the ram cap per slot of an intel i3 2100 processor?
AlHill
This processor can support up to 32GB:
https://ark.intel.com/content/www/us/en/ark/products/53422/intel-core-i3-2100-processor-3m-cache-3-10-ghz.html
Per solt information requires you to check the motherboard specs.
[If you find any Intel driver you might need, download and save it now.]
Vx1
Thats weird since when i went to buy me a new ram they said second gen processors only hold up to 4gb ram per slot
Dan0987
This is probably only correct (partially) for the H61 chipset with four filled DIMM slots. But this is a limitation of the chipset, not the CPU.
Vx1
So if my board is an ASUS H61M-K with TWO DIMM slots and the same chipset you said will it hold up 8gb of ram per slot?
Dan0987
Yes. Refer to the user manual (page 25) for confirmation.
AlHill
@Vx1   It is like I said in my first post, check the motherboard specs.
