17163 Discussions
How to Protect my Intel Core i9-14900K
Woofie
Greetings!
I just built my rig, its been awhile [years] so i am rusty, being that there is always something new but on that note. I did update the Bios to the latest but i was wondering if there was anything else that i can do to protect it? I have the Rog Ryujin III 360 Extreme as the cooler and while playing games like Cyberpunk, the Voltage on the Screen goes up to 1.445V but then will shoot back down to 1.335V Is that normal? is that okay? should i tweak the bios?  Did Intel release some form of update to correct what was wrong with the CPUs?
CPU: Intel Core i9-14900K
GPU: Nvidia RTX 4070
SSD: Samsung 990 Pro M.2 2TB
RAM: 2x31.5GB
MBD: Asus ROG STRIX Z790-A GAMING WIFI S
DeancR_Intel
Hi Woofie,
Thank you for posting in the Community.
I wanted to provide you with some important information regarding your Intel Core 14th Gen desktop processor.
Intel has addressed the Vmin Shift Instability issue for these processors with the 0x12B microcode update. Newly installed 13th and 14th Generation Desktop processors with an updated BIOS containing this microcode update and utilizing Intel Default Settings are not expected to experience this issue.
Intel’s guidance is to keep overclocking (OC) disabled by BIOS default. Typical overclocking can be done with the SVID limiting function enabled. Extreme OC users can bypass the SVID limiting mechanism by disabling the “eTVB feature.” Please note that when disabling the eTVB feature, the system will be subjected to elevated voltages, so it should be done sparingly.
Please be aware that altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components and may reduce system stability and performance. Product warranties may not apply if the processor is operated beyond its specifications. Check with the manufacturers of system and components for additional details.
As for the behavior of your system, this is normal.
Dean R.
DeancR_Intel
Hi Woofie,
Dean R.
DeancR_Intel
Hi Woofie,
Since I have not heard from you, I will be closing this thread and no longer be monitored. If you wish to continue with the troubleshooting, please feel free to contact Intel Customer Support or create a new thread.
Dean R.
