16766 Discussions
How to connect two p4 intel motherboards by a single BUS?
I am trying to connect two mother boards via single bus.
I wanted to use the processors of second motherboard using first motherboard...
Can anybody help me..???
Hello;
This operation can not be possible since you need 2 processors in order to boot 2 desktop boards, you can not boot 2 different desktop boards with a single processor.
I just want to use the unused processors of other motherboards by connecting then on single BUS.
Then how can i do that ?
I am afraid that his operation can not be possible, as I explained you before, your need a processor install on both desktop boards in order for the system to boot.
DSilv11
Valued Contributor III
Are you refering to CLUSTERING where you have mutible systems conected together (usually by ethernet) but running a single operting system?
http://en.wikipedia.org/wiki/Computer_cluster http://en.wikipedia.org/wiki/Computer_cluster
Computer cluster is loosely coupled system.
I want to create a tightly coupled system. Consider the example of IBM Blade Server.
I want to implement similar concept using old motherboards.
http://en.wikipedia.org/wiki/Blade_Server http://en.wikipedia.org/wiki/Blade_Server
DSilv11
The IBM blade center contains up to 14 separate servers connected to 2- gigabit Ethernet switch as the primary interconnect.
The system uses 4 common power supplies, 2 blowers and 2 Chassis management modules to allow for remote management.
The backplane provided the electrical interconnect for the devices and a private 100m Ethernet management channel to the components.
A secondary fabric could be used to add 2 additional switches for Gb, Fibre channel or inifinaband.
If your trying to mimic the interconnect on this system, all you need is a simple dual gigbit network.
The blades were frequenly used indivulally as part of a IT infrustucuture. One for DHCP, one for mail, one for SAP, etc.
Or as parts of a standard cluster.
This link will take yo to a Intel white paper on High Availability Server Clustering Solutions
http://www.intel.com/design/network/papers/251574.htm?wapkw=(clustering http://www.intel.com/design/network/papers/251574.htm?wapkw=(clustering)
I want to use the processors of old computers into a single unit so that the processing power is increase.
Since their is no use of old processors if used individually.
I just want to combine the processing power.
Any Suggestions how it can be done ?
