I am looking for information about turbo steps of 6126 gold processor, I have logged a case at Intel and HPE too; but, no progress in finding it. Could you guys please help me in this regards.
I have a server with the following config
Four (4) Intel® Xeon® Scalable 6126
Processors only (Gold)
- CPU Frequency: 2.6 GHz (Max Turbo Boost
- Cores: 12
- Level 3 Cache: 19.25 MB write-back
- QPI Speed: 10.4 GT/s
- UPI Links: 3 per processor
- Max TDP: 125W
- Memory Type: DDR4- 2666
- Intel Hyper-Threading Technology (HT)
I have details about "number of active cores/ maximum core frequency in turbo mode GHz" for 6126 processor. But, would like to know the turbosteps for the same.
Considering the old processor E5-4620 v3, I have below furnished table. I am looking for Intel Xeon Scalable 6126 gold processor's number of turbo steps (which is in center column in the below table) to reach the max frequency in turbo mode.
E5-4620 v3 - The Turbo Boost setting of 2/2/2/2/2/2/3/4/6/6 translates to the following table:
# of
Cores Active
# of
Turbo Steps
Max
Frequency
10
2
2.2 GHz
922.2 GHz
822.2 GHz
722.2 GHz
622.2 GHz
5<td nowrap="nowrap" style="border-width: medium 1pt 1pt medium; border-style: none solid solid no...- Tags:
- Intel® Xeon®
Hi AshokPakki,
I am sending you the Intel® Xeon® Processor Scalable Family Specification Update document. It contains the maximum speed per Core with Intel® Turbo Boost enable for the Intel®Scalable processors including the Gold 6126 on page 13.
https://www.intel.in/content/www/in/en/processors/xeon/scalable/xeon-scalable-spec-update.html
The turbo steps were not published; however, it provides with the maximum speed per Core.
I hope my answer helps you.
Miguel C.
Intel Customer Support
Hi Miguel C,
Thanks for the reply, as I mentioned in the description; I already have that information which you shared.
I am looking for number of turbo steps as I furnished the table of v4 processor (looking for centre column numbers for 6126).
Ashok Kumar Pakki
Hi AshokPakki,
I will escalate this to see if we can get that information for you. In the meantime please let us know if you need something else.
Eduardo_B.
