16777 Discussions
I am seeing this machine check exception error on a come module with with E2897 CPU and the kernel version used is 4.9.119-yocto-standard.
ajust3
CPU 1: Machine Check Exception: 4 Bank 0: 9000000020000003
mce: [Hardware Error]: TSC 8f0ad20006
mce: [Hardware Error]: PROCESSOR 0:30679 TIME 1556882638 SOCKET 0 APIC 4 microcode 90a
mce: [Hardware Error]: Run the above through 'mcelog --ascii'
mce: [Hardware Error]: CPU 0: Machine Check Exception: 4 Bank 5: f40000400090000f
mce: [Hardware Error]: TSC 8f0ace4c12 ADDR 95d6050
mce: [Hardware Error]: PROCESSOR 0:30679 TIME 1556882638 SOCKET 0 APIC 0 microcode 90a
mce: [Hardware Error]: CPU 1: Machine Check Exception: 4 Bank 5: f40000400090000f
mce: [Hardware Error]: TSC 8f0ad20006 ADDR 95d6050
mce: [Hardware Error]: CPU 0: Machine Check Exception: 4 Bank 0: b600000032100810
mce: [Hardware Error]: Machine check: Processor context corrupt
Kernel panic - not syncing: Fatal machine check
do_IRQ: 0.193 No irq handler for vector
Failed to insert
ajust3
Hi all
Is there anyone facing similar issues due to MCE triggered due to the BUSINIT error .
let me know if you have any idea regarding the root cause for this issue and solution if any ..
Alberto_R_Intel
ajust3, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance to your inquiry, could you please confirm the model of the Intel® processor that you are using?
We looked in our official web site for the Intel® E2897 Processor and that model is not showing:
https://ark.intel.com/content/www/us/en/ark.html
Or, you can also provide the SSU report, that report provides the model of the Intel® Processor as well as some other details of the components installed on your computer:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
To attach the report, once you choose "reply" select the "clip" icon on the lower left corner.
Alberto R.
A Contingent Worker at Intel
Alberto_R_Intel
ajust3, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R.
ajust3
hi Alberto
please find the CPU information. wrongly mentioned earlier as "E2897" sorry ..it is E3897
processor    : 0
vendor_id    : GenuineIntel
cpu family   : 6
model      : 55
model name   : Intel(R) Atom(TM) CPU E3827 @ 1.74GHz
stepping    : 9
microcode    : 0x90a
cpu MHz     : 1749.300
cache size   : 512 KB
physical id   : 0
siblings    : 2
core id     : 0
cpu cores    : 2
apicid     : 0
initial apicid : 0
fpu       : yes
fpu_exception  : yes
cpuid level   : 11
wp       : yes
flags      : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov
pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm c
onstant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf
 pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse
ajust3
Hi Alberto
we are currently using 4.9.119-yocto linux running in our CPU
We are not using windows we are facing the issue only in Linux.
Can I use this tool in the link to generate the SSU report in yocto ?
https://downloadcenter.intel.com/download/26735/
Alberto_R_Intel
ajust3, Thank you very much for confirming those details.
You mentioned that you are using the Intel® Processor E3897, still, that processor is not showing in our official web site:
But I can see in the report that you provided that the actual model of the Intel® Processor is Intel Atom® Processor E3827. As you can see in the link below this unit is an Embedded Processor, so in this case, the best thing to do will be to submit your inquiry in our Intel® Embedded Communities support for further peer to peer assistance on this topic:
https://forums.intel.com/s/topic/0TO0P00000018NFWAY/embedded-intel-atom?language=en_US
Alberto R.
ajust3
Thanks Alberto
I will update the query in Intel® Embedded Communities support
Alberto_R_Intel
ajust3, You are very welcome, thank you for your response.
Perfect, excellent, for this scenario that will be the best thing to do, they will further assist you in there.
Any other inquiry, do not hesitate to contact us again.
Alberto R.
