The i3-4370 pictorial instructions for processor installation do not include the application of thermal paste. This is my first experience with an Intel i cpu, so I am a bit confused about using thermal paste on it. Does the fan design obviate the need for paste?
- Tags:
- Desktops
CPUs, both Intel and AMD, require thermal paste. The instructions should have mentioned that. By the way, you only need a blob about one cm in diameter. Using too much is as bad as using too little.
Topic Options
