16967 Discussions
I5 12400 multiplier
VRKHNV
hi, i bought an intel 12400 processor and i have a question. the cpu-z program shows the cpu multiplier as 4-44, but in all the reviews i looked at, the cpu multiplier was 8-44. Is this normal? Revision C0, SRL4V, X202N803
Jean_Intel
Hello VRKHNV,
You should know that the information you are seeing is from a third-party software; we don't validate this type of software because we have no control or understanding of how they work and test the processor to report this information.
Have you experienced any performance issues with your system?
Jean O.
VRKHNV
I so love it. yes i have an issue. I don't know if I bought a right working sample or a defective one
Jean_Intel
Hello VRKHNV,
Thanks for your response.
For testing your CPU, you can try using our Intel® Processor Diagnostic Tool. (Intel IPDT) :
  • Download the Intel PDT (https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool)
  • Once installed, the Intel® PDT starts testing the processor using the default configuration. Two windows might appear to show the test is in progress.
  • When the Intel® PDT completes, the testing status will display either a PASS or FAIL.
  • Alternatively, you can open or save the test results file every time after the test run by clicking on file > view results file, file, then save as to any location you specify.
Jean O.
Jean_Intel
Hello VRKHNV,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello VRKHNV,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
