16974 Discussions
I5-9400f is soldered or not
JPark91
AlHill
This says it uses a LGA1151 socket, which means it is NOT soldered.
https://ark.intel.com/products/190883/Intel-Core-i5-9400F-Processor-9M-Cache-up-to-4-10-GHz-
Doc
JPark91
9900K uses LGA1151 socket, but it is soldered
AlHill
Then, the documentation is incomplete or incorrect. An Intel support engineer will have to confirm.
Doc
Leonardo_C_Intel
Hello everybody Thank you for posting in the Intel Community. All.Hill is correct the Intel® Core™ i5-9400F Processor in not soldered to the system motherboard, JPark91 could you let me know where did you find a soldered Intel® Core™ i9-9900K Processor? (Links or system model with the soldered processor) Hope this helps. Regards, Leonardo C. Intel Customer Support Technician Under Contract to Intel Corporation
BryanFury
Hey there sir LeoC
With all due respect, I'm not entirely sure whether You're trolling, or really don't know. The question/topic is pretty obvious, eventhough people in the topic itself can't correctly name what they want. The question is, whether 9400f uses the same iridium type solder upon gold plated ihs as for example 9900k, and most likely other 9xxx cpus. The solder question regards the ihs vs. silicone die iridium solder, NOT in any case integration of cpu itself to system board.
Hope this helps explain the situation sir
With kind regards
Bryan​
