16876 Discussions
I7 14700k strange spikes of temps
Cris86
Hi everyone, at the end of december 2023 i made my new build which is composed by the i7 14700k mounted on a MSI PRO Z790-A WIFI (MS-7E07) and cooled by the NZXT Kraken Elite 360 RGB and placed inside the NZXT H9 Flow case. Everything works fine (i have some problems with the NZXT Cam app but is not linked to this thread) but even i know that the new i7 can run hot, i noticed strange behavior by checking the temps with HWiNFO during my daily use (i always been a bit paranoic about temps even with the old pc).
I'll explain: At the moment i use only MSI Center and HWiNFO64 while i was forced to disable the NZXT Cam (for the issue above, probably due to some bugs in the recent updates of the app that sometimes causes the shutdown of the USBs ports at the boot of them pc, and forces me to shutdown the pc via button because the keyboard and mouse won't work anymore until reboot even for two months i never had any issue with both programs running together). Anyway as said i use MSI Center with the user scenario set to personal with fans around 40% until the temps reach over 50-60° so then the fans increase to adapt to the temperature.
By checking during the normal daily use (firefox with 4-5 tabs opened, maybe a couple of programs running but doing nothing heavy and some normal apps in the tray + windows doing his windows things in background where the CPU never went over 10-15%) i noticed via HWiNFO64 that even in my room the temps are normally between 18° to 22° and the temp of the core is for the most of the time between 27° to 33° (which are extremely good temp for this kind of processor) sometimes HWiNFO64 records some spikes of temp that can reach even 70° or 80° (for very short amount because the medium temp is always low) even the pc seems idling.
By checking the single cores temp, i noticed that some of them sometimes have spikes of 20°-30° higher than others.
When i made the pc, i did some bench test and with Cinebench i reached under load temps of 89-91 which are normal. I started chcecking deeper the temp due to these spikes that to me seems strange with the CPU barely over 5-10% or, like yesterday, while i was in game (Assetto Corsa) when i noticed a lag of a couple of seconds and i discovered that the temp reached the 92°.
Is this normal or i should be worried?
Attached some screens from HWiNFO, i hope to be exaustive enough to let you understand my worries and give me some feedback, thanks to everyone.
Cris
RamyerM_Intel
Hello Cris86,
Thank you for posting in the communities. I want to let you know that the maximum temperature for this CPU is at 100 degree celsius, which means that the temperature data you have mentioned is within the allowable temperature. Having temperature spikes or having high or maximum temperatures while running a workload—such as games—isn't necessarily cause for concern. Intel processors constantly monitor their temperature and can rapidly adjust their frequency and power consumption to prevent overheating and damage. I do understand that you want to make sure your system has no issues. I just want to ask, if you monitor the temperature in the BIOS, what does it show? You may also share with us your SSU logs so we can be more familiar with your system. Feel free to run our Intel® Processor Diagnostic Tool and share the screenshot of the results in this post. I will be waiting for your reply.
Ramyer M.
Cris86
Hi Ramyer, thanks for your reply first of all.
I know that this kind of CPU can run hotter, and i was aware of it before purchasing it, but what concern me is that the CPU have this peak while doing nothing and if put on stress (like few minutes ago when Adobe Illustrator was using the CPU at 100%) the temp hit immediately the 89° with some of single cores at 100° (they became red immediately on HWiNFO64).
My precedent CPU was not so hotter (and it was extremely old) but it never ever reached the TJ Max even when was under extreme load (100% of the CPU for a lot of time) while this one reaches it immediately.
Last time i checked the BIOS the temperature were fine (28-30°C) and i could double check it tomorrow when i bootup the pc again.
Attached the SSU result and the result of the Intel Processor Diagnostic Tool 64bit and some screens from HWiNFO64 recorded at the end of the test which shows the low and max values during the test.
As you see from these result, the CPU reached the thermal throttling quite easily, and it stay on throttling until the specific single test ended. The liquid from the cooler reached the 43° degrees while in my room there's 20.9 right now.
--- IPDT64 - Revision: 4.1.9.41
--- IPDT64 - Start Time: 03/04/2024 18:03:48
-- Testing
CPU 1 - Genuine Intel - Pass.
CPU 1 - BrandString - Pass.
CPU 1 - Cache - Pass.
CPU 1 - MMXSSE - Pass.
CPU 1 - IMC - Pass.
CPU 1 - Prime Number - Pass.
CPU 1 - Floating Point - Pass.
CPU 1 - Math - Pass.
CPU 1 - GPUStressW - Pass.
CPU 1 - CPULoad - Pass.
CPU 1 - CPUFreq - Pass.
IPDT64 Passed
--- IPDT64 - End Time: 03/04/2024 18:07:35
PASS
KrissyG
New Contributor II
the spikes are 'normal'
even with water temp at 20°C the whole time, the CPU can reach 100°C within less than a second, and after the test it just drops to idle temp as if nothing happened.
I too was used to temps slowly rising and slowly falling, but here its not the case.
The whing with AIO's is, while your room temp is like 20°C , the AIO does not get  that air temp.
Your AIO gets preheated air, from your motherboard and graphics card, so the real air temperature for teh AIO may as well be over 30°C.
When i run tests with no limit, at the beginning there is no thermal throttling usually, but few seconds later the CPU get's spammed with thermal throttling all the time.
The difference in temps between certain cores, as i observed, reach sometime smore than 15 degrees. and about 20 degres between performance and efficiency cores. I recall on the i7 3930k(6 cores), there was 2 degrees difference only.
Cris86
Hi KrissyG, thanks for your feedback.
As said, i was aware that this CPU is hotter and that's why i purchased a 360 AIO cooling system and a extremely ventilated case.
I know too that the AIO temp is affected by the temp from the elements inside the case, that's why i asking this before summer hits my zone because if i have this temp with 20° inside my room, this summer when i will have 30-35° like in the past one, the temp will increase even more for the CPU.
I agree that being trained to see temps increase slowly and drops at the same speed, having this fast spikes can cause concerns, but as said, i never put the system on an unlimited test, my spikes happens with only few programs running while the CPU is basically almost in IDLE meanwhile when something uses the CPU more than 30% for few seconds the temps reaches fast the maximum and if the uses reaches the 90-100% the throttling starts.
About different temps from each core i agree, as said, mine have even 20-30° difference between each others independently from the fact that the CPU is throttling or not.
KrissyG
New Contributor II
ahh, this kind of spikes, you may refer to Antimalware service, which once a while draws close to 100W while CPU usage is low.
Windows update does same once a while too.
It usually activates itself when PC is unused.
Curious, some of the screenshots show the pump to go max rpm, have you tried to change the profile fot the pump?
An AIO has rather little amount of liquid, so at high rpm it will circulate very quickly without the chance to give off the heat to the air that runs through the radiator. I would test it at 50% rpm and see if that changes anything.
Cris86
Don't know if the spikes can be caused by Windows Defender, Malwarebytes or else, but is quite strange because it has a pattern up-down pretty fast which can't be keep tracked by eyes (at least not by me while i'm working).
About the speed of the pump maybe the screens you're watching are the one while the CPU was as it max? Because i running the MSI Center (before i was running also the NZXT Cam which in the lastes version causes me shutdown of the USBs forcing me to reboot the pc by pressing the power button during the first boot of the day sometimes. I'm working with their support to solve this issue) but on MSI Center the CPU Fan and the Pump fan are set lower than max
KrissyG
New Contributor II
@Cris86 wrote:
this shows exactly what i said, the pump runs probably like 80% or faster even when you browse. This profile would be good for teh AIO fans, but for the pump is too extreme.
Like i said, if the liquid goes to quickly through the radiator, it has no time to give away all that heat.
In the long run it will not change that much, as the liquid will remain at high temperature.
I don'T have time to swap radiators, else i could provide you with graphs on different pump speeds, TDP and radiator fan speed too. You would see how little difference there is between 50% and 100% pump speed. But also how big difference it makes if at 50% pump, the fans are at 80~100%. However, i can not provide any data on internal mounted radiators.....external is the best way.
That being said, there may be a different problem you are facing.
Cris86
I'm probably missing something (it's my first time ever with an AIO cooler because i always used air-cooler before). I can try to set the Pump Fan 1 to 20% until the temp reaches over 50°, but as said the liquit temp with the standard setting never went over 43° while doing the Intel stress test, so don't know how this can affect it, but a try maybe is worth. (Since i was writing this post i reduced the speed to 20% until the temps hit 50°, so let's see how it will behave)
This morning (before reading your post and doing what above) while i was packing 2gb of stuff with 7zip, the cpu went in throttling only doing that. I don't think is normal to be honest that (even a extreme powerful) CPU went in thermal throttling only doing a "stupid" action like packing few hundreds of mb... or not?
KrissyG
New Contributor II
possibly a ridiculously fast setup.... your RAM is at 6000MTs, SSDs run at 5GB/s up to 7GB/s.
Maybe the bottleneck in your syetem is the CPU....that is why it is being used to 100%?
Except, i had to set some rather odd values in 7zip to achieve extensive power draw,
to be honest, no one uses such settings for file compression.
And that actually did not even make my 2GB/s slow SSD sweat, i would claim the CPU was in the beginning the slowest part,
then it was the RAM, my DDR4 RAM does 2133MTs, which is why the CPU suddenly dropped power usage to 42W, and only for short periods of time did the CPU use 'more' power.
Default 7zip settings:
With default, the result is just one spike, it took like 3 seconds,...... the second spike after that is a random one i guess.
By the way, not sure if PWM pumps rin at 20%, but i know that 3 pin connected fans and pumps will not run under 30%, most pumps, such as mine will not start below 50%, i can lower it to 40% once it started, but if it stops for some reason it will not resume from 40%.
Cris86
Hi KrissyG, thanks for your precious help, much appreciated.
By doing what you suggested (reduce the pump speed) i reduced also a bit the whole temp when some peak happens (from 74 to 60 most of the case in idle when windows doing his windows thing with some tabs opened and some programs in idle them too).
While i was packing with 7zip, i have to admit (i forgot to say it), i was packing that amount of data from an HDD which i use for storage of downloaded stuff which could be the cause of the bottleneck while packing.
This are my 7zip settings.
The strange things is that yesterday i noticed that the CPU went in throttling even without reaching the 100° on any core. Is this normal? Day by day, my questions increases alongside my doubts
About the pump, as said i'm a complete newbie of water cooling, so i don't know if i'm doing something wrong.
This is how i set after your suggestion:
About the pump, i don't know if i understood right what you say: you mean that if i put the pump speed under the 50%, if the CPU need more speed to cool itself the pump will not restart once reduced to lower than 50%?
There's a way to check the things you say about the pump?
Thanks for your time,
much appreciated.
KrissyG
New Contributor II
hmm, so there was a noticable change in the readings, i was expecting some ipact, but not that much.
When you were installing the AIO, could you hear....like if the air would be trapped in the radiator?
Maybe there is too much air in the loop, and the pump at full speed manages to pull some air with the liquid.
The best way to know if there is too much air in it, is to unmount the radiator and shake it few times.....there will be always some air trapped in an AIO, but there is a posibillity that either some liquid escaped, or they did not fill it up well enough.
Opening AIO loop is not a good idea, just so you know, anything that gets into the liquid may result in being shredded into pieces and make the cooling work less efficient than before.
i saw 6MB/s while 7z was doing the compression on ultra setting, and from what i recall, most HDDs will have 80MB/s up to 200MB/s read speed and like 80MB/s average write speed, so on high settings the HDD will not limit the speed, unless it has tons of bad sectors....
Even XTU can't catch up to the speed of the hardware sendin in the data, the first spike is real and the CPU was using the set limit, thus the TDP throttling (blue spike) took place, the second TDP throttling was a false reading.
I would assume that a third party software such as HWinfo would get same readings or would be even slower since it gets lower priority than Intel software.
And then there is this here, 900 Terawatts peak power consumption, obviously something delivers false data or the XTU has too many bugs. It has bugs bcoz the mods here on forum confirmed it.
Yes, the fan speed look good.
As for the pump speed, you would just have to test it, like set a TDP limit to a value at which the CPU will not get thermal throttling for like few minutes, and then try different % speed for the pump.
So far i have never seen such detailed specs as to what is the minimum voltage or % at which the pump will start, nor a detailed graph showing the cooling performance relative to the pump speed.
That is something you would have to find out for yourself, through hours of testing.
Like i said, i doubt there is some details about the AIO you have.
On top of that, PWM fans and pumps should have the 'zero rpm' capabillity, so that it can be even turned off automatically if the PC is for exampel in idle or pause/hibernation etc.
My main concern mentioning this was the fact, that at too low rpm the pump may either not want to re-start, or that it get's stuck in a re-start loop, where it runs few seconds and then stops, restarts and so on...
I could assume neither the motherboard, nor the NZXT software allows setting a rpm, that makes the pump stop or stop working while the temperature falls under set minimum.
I would suggest to run tests, and set a soft slope for the pump, like this for example
or this
Aso do something like here below, and run CPU stress tests for like 10~20 seconds with different TDP values, like 100W, 150W and 200W, at low pump speed i would not let the CPU have the unlimited power.
While running tests i would suggest to make breaks between tests for like 1 hour, or until the PC in idle achieves lowest CPU temperature possible, so that you start new tests with similar conditions.
Such tests would show you what impact the speed of the pump actually has.
Also i would suggest to run the fans on the radiator at 80~100% for all tests.
I would expect to see lowest temperatures at pump speeds below 60%.
Edit
on the NZXT page of that AIO it actually says the specs for the pump
So 800rpm is the minimum from what it says
It also shows something rather problematic, the CPU block made of copper and radiator made from aluminum.
This this will literally destroy itself after the liquid loses it's dielectric properties
....NZXT does not want it to last too long it seems.
KrissyG
New Contributor II
.....this forum obliterated my previous reply, guess i edited it too often or i posted something....anyway...
"While i was packing with 7zip, i have to admit (i forgot to say it), i was packing that amount of data from an HDD which i use for storage of downloaded stuff which could be the cause of the bottleneck while packing."
If your HDD was the bottleneck, you would never get close to using any performance from your PC at all.
While testing i saw speeds of some 6MB/s from my SSDs, a HDD can easily do 80MB/s write and up to 200MB/s read, so the HDD was not even sweating.
"The strange things is that yesterday i noticed that the CPU went in throttling even without reaching the 100° on any core. Is this normal? Day by day, my questions increases alongside my doubts"
The readings were probably ot correct, or the CPU throttled the perfoemnace so quickly, that the reading of 100C did not reach the HWmonitor.
XTU shows me power throttling whiel showing me a TDP that is way lower than the limit i set.
"About the pump, i don't know if i understood right what you say: you mean that if i put the pump speed under the 50%, if the CPU need more speed to cool itself the pump will not restart once reduced to lower than 50%?
There's a way to check the things you say about the pump?"
Yes, for example, my Gigabyte motherboard allows me to set 10% speed on fans and even the pump, but almost all of the fans i have will not start if less than like 30~35%. As for the pumps, i have 5 in total, only one in use, but none will start under 50% each time.
Not sure about PWM fans/pumps tho.
This is an example, i actually do not use the motherboard to run the pump, i use it to run in-case fans only.
As for the slope on the fan speed for the water cooling, your look good.
But the pump is still too aggressive.
According to specs of your AIO, it goes as low as 800rpm, not sure at what % do you get 800rpm.
But i would suggest a setting such as this here:
or this:
Runs some tests and see when you get better temps.
I reccomend using XTU, as you can change the time frame for like 1 hour, to see the change in teperatures better.
Example, here i put a straight line with MS Paint on the screenshot from XTU graph, where you can see, the temp is rising slightly (the part which i mean os only on the right side of the graph)
RamyerM_Intel
Hello Cris86,
I appreciate that you and KrissyG has been active in this forum. It is indeed good for our community and we encourage you to do so. However, since I noticed you are inquiring specific details about setting up your CPU cooler, it is best to reach out to the cooling provider for a mode detailed assistance on setting this up for you. You may use this link: https://nzxt.com/support
Ramyer M.
Cris86
Hi @RamyerM_Intelabout about NZXT support I already asked support there without any luck (if the cooler works for them there's no problem).
I asked help/question here about the temperature of your product, but as today after i provide you the info from the test i've done, i didn't yet received any response, so i'm waiting for them when you can, thank you.
I would say thanks to @KrissyG for the time spent with my question (i will read and reply to your post later when i'm a bit more free).
Cris.
RamyerM_Intel
Hello Cris86,
Given that the diagnostic tool has indicated a successful test, my focus is now on ensuring that your cooling system is correctly installed and functioning optimally. This is the reason why I shared the support for your NZXT Kraken Elite 360 RGB. Additionally, the temperature in the BIOS and monitored is still within the maximum temperature allowed by the CPU which is 100 degree Celsius .As stated in my previous post, Intel processors constantly monitor their temperature and can rapidly adjust their frequency and power consumption to prevent overheating and damage. It is important to make sure first that the cooling solution is properly configured so we can isolate if the temperature is caused by the CPU or by the cooling solution. I hope I was able to clarify this for you.
For now, it would be best to check NZXT support about their cooling system before trying to troubleshoot the CPU. If you have further questions feel free to let me know.
Ramyer M.
Cris86
Hi , as far as i know (since NZXT support didn't even solved the issue that causes my USBs shut off while loading their software at the moment) the cooler is right mounted. In fact, if wasn't, i could not have 26-30° for most of the time while windows is idling, but at least twice higher temp than this i think.
I don't say that something is wrong with the CPU, my toughts were if those spikes are normal or not, because even on my oldest laptop (which even not so powerful) the CPU is cooler even staying extremely high due also to the smallest case and cooling system (under heavy load it never went over 70° while this new CPU cooled right it keep having spikes on 70-80 degrees when the CPU went between 20 to 40% and it immediately reaches 100 and throttling on 90-100% usage). That's all
But at this point i will try anyway to ask them an opinion about those spikes of temps.
KrissyG
New Contributor II
@Cris86 wrote:
.....the cooler is right mounted. In fact, if wasn't, i could not have 26-30° for most of the time while windows is idling, but at least twice higher temp than this i think.
nah, on idle you could put the water block or any air cooler on the CPU without thermal paste, and if teh piece or copper on the CPU is not crooked or scratched, you would be getting 30~40°C on idle too, you would just have to torque the screws a little bit harder.
Obviously, the PC would BSOD possibly, since on startup it would draw more than 100W, so a TDP limit or power saver would enable startup without too much heat....not a good idea to not use thermal paste.
Cris86
@KrissyGi probably explained not well what i was thinking.
I'm pretty sure that the cooler is right mounted because i don't think the pc would have passed the cinebench test i did after building it and the intel test of few days ago if the cooler was not right mounted. But i don't know, to be honest more i get deeper, much question came to my mind. I build few pc in my life and never had any kind of issue.
Maybe this new CPU requires the cooler mounted in a specific position? (mine is placed vertically on the side of the CPU instead of top which is ok based on many people said on the internet) or the contact frame which almost everyone suggest to use with those new CPU?
I am open to any ideas, because at the moment I am afraid to use the pc I decided to build to replace my old one that deserved retirement (I'm worried about damaging something after spending so much money), and that is not good to be honest.
KrissyG
New Contributor II
I guess that contact frame costs like 10~15$ so you could try it out, but that will require taking out the motherboard if your PC case does not have a cutout for it. So you will end up 'rebuilding' the PC.
Secondly, that contact frame will work only if the CPU is somewhat crooked....
For me a contact frame will not chaneg anything, the water block i have comes with a massive back plate, nothing is going to flex, and i can torque to the point the CPU would probably break or stop working.
And on reviews of your AIO i see no springs on the mount, do you just torque it untill there is a huge resistance or is there some game? If no springs, then it means that it uses the flexibility of the mount itself, in which case, a contact frame will bring in a positive change.
By the way, what thermal paste did you put on there? and how much of it?
Thick thermal paste in bigger amounts will result in bigger gap between the water block and the CPU....the actual CPU chip sits perfectly in the middle and is a rectangle, it is way smaller than the copper IHS that sits on it. So if your wtaer block has for some reason better contact on the edges, then it is useless, bcoz you would need the contact right in the middle slightly elongated:
As for the way the radiator is mounted.....would not be a bad idea to unmount just the radiator, and put it highter than the CPU and also to try different positions while doing so, maybe there is some air trapped inside?
Edit*
The backplate on your AIO is made of plastic?
YouTube just suggested me a review where some dude showed all its components in high details, and the backplate looks like it has molding traces....such as plastic mold woul have. If it's made of plastic, then you should definitely try out that contact frame. I never seen a backplate made of plastic....what in the world were they thinking.
Cris86
No idea to be honest if the contact frame could improve or not, it was just an idea. I've strenght the screw as reported in the manual by NZXT, so not too tight and nor too soft. I used the Noctua NT-H2 thermal paste applied in the same way i applied on all the pc i made in my life, so not too much, not too less.
I think the backplate was plastic but i don't remember right now to be honest. (from this pic it seems plastic).
About the radiator, i could try to mount it on top, in order to see if something went better. My pc is placed under the table, so i put the radiator on the side of the case in order to let the air be pulled out from the side and allow the top case fans to throw up some fresh ait to avoid having higher temp above the pc under the table. My case have a fron panel in glass, so no chance to place some fans in front to help air came in.
Thanks @KrissyG
