I7-2600 Memory
i7 microprocessor-2600 only supports memory DDR3-1066/1333? You can not usememories of 2133?
Adolfo_S_Intel2
This processor supports only DDR3-1066/1333, so installing higher memory will force the system to run out of specifications, causing unexpected behaviors.
I strongly recommend using fully supported RAM, make sure it is 1.5 volts.
Thank you very much. Very useful information.
