16764 Discussões
I7-4702mq -> Compatible MoBos in Argentina
MMass20
Principiante
1.592 Visualizações
I have an I7-4702mq Processor which was running on an MoBo Asrock IMB-180.
MoBo is now dead (Suppose that iGPU failed and not even beep from BIOS is heard).
The problem is that I have no chance to replace it because it is not sold here.
Can you please tell me other MoBos compliant with this processor? And I will try to get one in Argentina.
I wouldnt like to thrown away this processor as it had only been used for 6 months.
Thanks and Regards,
Mariano
5 Respostas
AlHill
Superusuário
1.365 Visualizações
If the processor graphics failed, then the processor is not worth anything, as the graphics are built in to the processor.
However, if you want to try a different board, look for one that has socket PGA946. Then, you must verify that the boards bios supports your i7-4702mq.
 https://ark.intel.com/content/www/us/en/ark/products/75119/intel-core-i7-4702mq-processor-6m-cache-up-to-3-20-ghz.html
You may want to try a different power supply on this board.
Doc
MMass20
Principiante
1.365 Visualizações
Hi Al
The graphics processor is a different chip, Intel Graphics HD 4600. I don't have a different board to test micro with socket G3.
MoBo only accepts 12volts Power, already tried with a normal PSU (bridging green and black) and connectin 4 pin connector on board and the result was the same.
AlHill
Superusuário
1.365 Visualizações
No, if you have a i7-4702MQ processor, the 4600 graphics are included in the processor.
Doc
AlHill
Superusuário
1.365 Visualizações
And, try a different power supply. The jumper test proves nothing.
Doc
MMass20
Principiante
1.365 Visualizações
Hi Al, thanks again for answering.
I have not explained myself correctly meaby.
This MoBo (Asrock IMB-180) has 12 volts connector, as in any notebook, of a power supply of 12V and 10A.
As you can see it also has a 4-pin ATX power connector, so i plugged this from a normal PC PSU, and thats where i did this bridging between green and black cables to power up PSU.
Responder
