16771 Discussions
I7 7820X Turbo Boost 3.0 Issue
MSeng
Hello there i updated my BIOS today and before that i was getting 4.3 Ghz each core when play games or stress my cpu for benchmarking. But now i am getting only 4.0 Ghz while doing the same? i do not understand whats the issue here. Could you please help me fix it?
n_scott_pearson
Best advice I can give (answering in the blind) is to check your BIOS configuration. Something may have changed during the BIOS update process. Often, resetting to defaults will clear changes like this.
MSeng
I have done that it did not help. chatted with intel support about this isue they wanted me to run the tool and they said that cpu was not getting more than 3.98ghz for some reason. and it could be faulty processor. I have sent MSI a ticket about the problem lets see what will they say.
Hello Thunderfap
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
MSeng
ah no thank you i have spoken with live chat a lot of times and my problems are gone! but thank you tho!
Hello Thunderfap
Thank you for your response
I am glad to know that the issue has been fixed
Leonardo C.
