Annonces
16857 Discussions
I9--14900K CRC-Error while unpacking ZIP Files and Bluescreens - Hot CPU
Gradye
35 867 Visites
My System:
Gigabyte Z790 Aorus Elite AX ICE (BIOS F3)
Memory 2 x 24 GB GSkill F5-7600 Ram (DDR5-7600 / PC5-60800 DDR5 SDRAM UDIMM)
CPU Intel Core i9-14900K
GIGABYTE GeForce RTX 2080 GAMING OC 8G (GV-N2080GAMING OC-8GC)
Watercooling Sharkoon S90 RGB AIO 360 mm
Behavior:
At the beginning I still have a benchmark score with the Intel Extreme Tuning Tool in the standard settings of a little more than 8000 points, after I noticed the problems, I made the attempts to stabilize the system and get at least approximately suitable performance. Now I reach a maximum of 5000 points in the benchmark and notice that the system is unstable and even slower. I´m not only get CRC errors when unpacking ZIP files, but also regular bluescreens. Apps are closing without a message and the temperature is above the Limit, when idle, so that the power will reduce without a reason.
Tested:
I change the Thermal paste (Aairhut GX-14 Thermal Paste, 15.7W/m.k)
I have already tried several settings and adjusted the power limits. In the meantime I have switched off the INTEL Turbo function and still have an unstable system with not even close to the performance I paid for. The settings of ICCMAX, CEP, TVB from a Intel Chart. reduce even more performance, so that I am more comfortable on the road than I can say that I have a power CPU. Does anyone have any idea what I can do to get into the range I paid for?
0 Compliments
43 Réponses
zzetta
Nouveau contributeur III
24 516 Visites
Hi. Try installing F1 BIOS, load defaults, then apply xmp and try again.
0 Compliments
Gradye
24 493 Visites
Hello zzetta,
Thanks for the quick reply. I checked the Gigabyte website and the F1 BIOS is no longer available for download, but I did see that F4 is available for download. I will try this once and then test the system only with the power limit set, which should then exploit the potential up to the power limits without BSD, CRC error, closing apps or with temperatures that are not justifiable. That would at least be close to the performance I paid for. Any further intervention in the setting beyond automatic seems a bit excessive to me, especially for people who don't have that much background knowledge about computers, in order to fix an Intel problem. Even flashing the BIOS goes far beyond the knowledge of most customer.
0 Compliments
zzetta
24 492 Visites
I have checked the motherboard page and there is an F1 Bios. Make sure you search for it carefully. The issue is not with Intel processors, but motherboard vendors changing AC loadlines without mentioning that in the patch notes of newer BIOS versions. I had a similar issue with my Gigabyte and rolling back to the bios from late august fixed everything. Try to give me the link for your motherboard. ALso make sure you select the correct Revision.
0 Compliments
Gradye
24 439 Visites
Yes, I saw that too. I quickly checked and upon closer inspection realized that it wasn't the right board. The BIOS has been flashed. I only adjusted the power limits to 121/253. Everything else remained the same. After restarting, encountered several Blue Screens, including:
  • Critical Process Died
  • Attempt write to read-only memory
  • wimfsf.sys
Only after disabling INTEL Boost was the system able to start. Attached are the BIOS, HWinfo, Intel Extreme Tuning Tool and other settings I found on the internet.
0 Compliments
zzetta
24 435 Visites
I'm glad that you could flash to F1. Please reset the bios to defaults and don't touch anything else. Try again to see if it crashes with everything on default.
0 Compliments
Gradye
24 397 Visites
Unfortunately, no success. I loaded the defaults and restarted the PC. Encountered several Blue Screens:
  • 2x KMODE Exception not handled
  • System Service exception
Then Windows started, but after a short time (10 sec) another Blue Screen:
  • Unexpected Kernel Mode Trap
Upon the second Windows start, another Blue Screen (4 sec):
  • Multiple IRP Complete requests
Restart (Blue Screen):
  • Clock watchdog timeout
Disabled Intel Turbo Mode and the system started. I restarted HWInfo and the Intel Tool.
0 Compliments
zzetta
24 373 Visites
Unfortunate. Please reseat your ram, try with one stick at a time. You might have faulty ram. Unplug your PC and check your cables from psu to be inserted correctly. After you did that reset the bios.
0 Compliments
smithjohns
21 351 Visites
Sure, it sounds like you're troubleshooting performance or stability issues with your PC, likely related to memory settings or overclocking. Here's a step-by-step guide to follow your instructions:
1. **Download and Install F1 BIOS**: Visit the website of your motherboard manufacturer and locate the latest F1 BIOS version for your specific motherboard model. Download the BIOS file and follow the manufacturer's instructions to install it properly.
2. **Access BIOS**: Restart your computer and enter the BIOS settings. This is typically done by pressing a specific key during the boot process, such as Del, F2, or F10, depending on your motherboard manufacturer.
3. **Load Default Settings**: Once in the BIOS settings, navigate to the option to load default settings. This option is usually labeled "Load Optimized Defaults," "Load Setup Defaults," or similar. Select this option and confirm to reset the BIOS settings to their default values.
4. **Apply XMP Profile**: After loading default settings, locate the XMP (Extreme Memory Profile) option in the BIOS settings. Enable XMP and select the appropriate profile for your RAM. XMP is a feature that allows your motherboard to automatically configure memory settings for optimal performance.
5. **Save Changes and Exit**: After applying the XMP profile, make sure to save the changes and exit the BIOS. This option is typically found under the "Exit" menu, and you'll usually be prompted to confirm saving changes before exiting.
6. **Test Performance**: Once your computer restarts, test its performance to see if the issues have been resolved. Monitor for any stability issues or errors, especially during demanding tasks like gaming or intensive applications.
Following these steps should help optimize your system's performance and stability by ensuring that your BIOS settings are properly configured. If you continue to experience issues, you may need to further troubleshoot or seek assistance from technical support.
0 Compliments
Gradye
24 344 Visites
The temperatures constantly trigger core throttling. I tested the Intel Tool once with and once without power limits. I can rule out the memory issue since it has been tested in another system where the memory runs stably.
Sometimes you get, with fewer GHz than the maximum settings, a better performance in benchmarks because core throttling isn't triggered. I've had better experiences with this system when I set the P-cores to a maximum of 5 GHz and the E-cores to 4 GHz, but that shouldn't be the case considering the price of the CPU.
Now the Powerlimits are set to 121/253 with the result attached to this post.
0 Compliments
zzetta
24 313 Visites
I was actually going to ask you about those high temps. Your cooler might not be working, or it is not mounted properly. Check the cables from pump, but you should first pull it out, reapply the paste and check if you did not forget to remove the plastic film from the pump block.
Also, regarding the ram, it's better to check if it's on the qvl of the motherboard.
0 Compliments
Gradye
24 303 Visites
That was also my first thought. I deliberately used better thermal paste, as mentioned above. The pump is working; that has also been tested. I've tried everything possible. Since I work in IT, I initially tried to solve it myself, and only after realizing that I'm not alone in experiencing issues with Intel's high-end CPUs did I decide to describe my problem here. My main concern isn't necessarily finding an immediate solution; I can work with manual settings. But imagine the customers who don't have the competence to implement the suggestions here in the forum, let alone know what a BIOS is.
0 Compliments
zzetta
24 253 Visites
You have abnormal cpu temps. I'm pretty sure your cooler is not mounted properly. Check for the things I suggested.
Yes, the cpu instability is a real issue, but first try to fix the cooling problem. You shouldn't have to limit your cpu to such drastic values. I have a 14700kf working with a Noctua u12a, a very small cooler and I'm able to continously hold 300w of power with no issues.
0 Compliments
Gradye
24 140 Visites
I specifically purchased this cooler and tested it with the same results.
DeepCool AK400 Digital CPU Cooler
0 Compliments
zzetta
24 135 Visites
Well, in this case, it might be possible that your cpu is physically busted. Contact Intel, or the local seller to give you a replacement.
But tbh, these weird temps tell me your cooling mechanism might be broken, or wrongly installed. I'm not trying to be disrespectful. Just my 2 cents.
0 Compliments
Gradye
24 119 Visites
As I mentioned, that was also my initial thought. I've applied new thermal paste multiple times, even bought better paste afterwards. The idea that the water cooler isn't seated properly every time I try seems unlikely, as I always get similar results. I even tried tightening it by hand to prevent the CPU from bending and experimented with increasing the pressure by tightening it further, but it didn't really bring about any improvement, and I tried this with both fan versions.
I guess I'll have to wait until Intel or Gigabyte come up with a solution that doesn't require BIOS intervention. I'm curious to see how they plan to roll it out, especially for those affected who don't have an IT background. It's unlikely they'll be easily persuaded to install a BIOS update or an Intel fix.
0 Compliments
zzetta
24 115 Visites
Your temperature issue is definitely not caused by the bios or the settings. It's either a physical defect in the chip or the cooler itself.
0 Compliments
Gradye
24 111 Visites
Those are the current temperature and GHz readings while idle with a YouTube video running.
0 Compliments
zzetta
24 093 Visites
It's quite high given that you reduced the power limits and the frequency of the chip. Definitely not a normal behavior.
0 Compliments
Gradye
23 949 Visites
in my opinion, especially after it was constantly at 100°C for the past two hours while we were testing what could help, it is normal. As I mentioned: 2 fans (AIO / Air). It's not that Intel CPUs can't handle high temperatures, but rather that they reach these temperatures very quickly without any apparent reason when Turbo Mode is activated, and then the CPU gets throttled. My screenshot shows that 5 GHz are not a problem for the P-cores without the temperature rising significantly. Now I'm getting better values than with the default settings from the BIOS, and the only things set are the power limits and Turbo Boost disabled.
The screenshot shows that all CPU cores are running at the same speed and are not being regulated, as far less power would be necessary for idle.
0 Compliments
zzetta
23 946 Visites
Show me a picture of hwinfo when you are testing the cpu. Show me the cpu package power and the voltage. It's on the enhanced menu of your cpu in hwinfo.
From what I can see you have abnormally high temps with such low vids
0 Compliments
Répondre
