16803 ディスカッション
IBIS model Request or equivalent IBIS model for JG82855GME
Pragathi_M_A
ビギナー
320件の閲覧回数
Hi Team,
I am working on SI simulation for a PCB design which involves the Intel chip "JG82855GME". This chip is used in the device in such a way that it is connected to 20 DDR1 memory chips from Micron. I am in need of IBIS model for the "JG82855GME" chip. Can you direct me from where will I have the .ibs model for the same. Also wish to know whether this chip is capable of handling 20 loads and a pull up termination resistor of 56 ohm connected to VTT.
Expecting your quickest reply.
Thanks in advance.
Pragathi
ラベル(1)
0 件の賞賛
2 返答(返信)
ArchieD_Intel
モデレーター
274件の閲覧回数
Hi Pragathi_M_A,
Thank you for reaching out to the Intel Community Forum. I will check this and will update you as soon as possible.
Archie D.
ArchieD_Intel
モデレーター
227件の閲覧回数
Hi Pragathi_M_A,
Please follow the steps outlined in our article, "How to Register and have Access to Intel® Premier Support," to create an account and contact IPS support. This is the appropriate procedure for addressing this matter.
Archie D.
返信
