17152 Discussions
IPDT 3.0.0.23 includes verification of engineering samples and possible graphics bug
ppara5
Valued Contributor I
I just installed IPDT 3.0.0.23 and noticed that it checks for engineering samples. Some people would say that it is easy to look at the CPU itself, but that's problematic if the CPU is already installed in a system, as it often is. Checking for engineering samples is a great addition.
Also, I noticed that the graphics behavior is slightly different. Before, if a system had a discrete video card, the graphics tests were skipped, with a message explaining that the PC has a video card so the graphics tests were not run. Now the message "Intel Graphics Device Module has a configuration mismatch" appears and the color spectrum and 3D graphics tests are run. The screen rotation test is not run. Then when the test completes, the real-time messages are erased and a new, longer list of messages is displayed, including "Intel Integrated Graphics Device not detected; test skipped." Are the two graphics tests exercising the Intel on-chip graphics or the discrete video card? And what's up with the "configuration mismatch"?
In case it matters, this system is i5-2500, DH67BL, and NVIDIA 430 running W-7 64-bit, all finely aged H/W and S/W.
ppara5
Good thing I saved the previous version 2.11.0.0. I'll only use the new version if I want to verify if a CPU is an engineering sample.
Allan_J_Intel1
I have tested IPDT using on-board graphics.
Allan.
ppara5
Now please test it on a PC that uses a discrete graphics card so IPDT is forced to use the logic I referenced.
--- IPDT64 - Revision: 3.0.0.23.W.MP
--- IPDT64 - Start Time: 2/8/2016 8:15:46 PM
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Mon Feb 08 20:15:46 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
End Time: Mon Feb 08 20:15:46 2016
Total Time: seconds: 0
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 61 degrees below max
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
CPU Frequency Test
Module Version: 1.0.14.64b.W
Test Result - PASS
Processor Name: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
Expected CPU Frequency: 3.30
Detected CPU Frequency: 3.30058
Expected Base Clock: 100
Detected Base Clock: 100.018
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Mon Feb 08 20:15:47 2016
Total Time: seconds: 1
Floating Point Test
Module Version: 1.0.10.64b.W
Start Time: Mon Feb 08 20:15:47 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 417.6
Error: 0
--- Floating Point Test Passed!!!---
End Time: Mon Feb 08 20:15:49 2016
Total Time: seconds: 2
Prime Number Generation Test
Start Time: Mon Feb 08 20:15:49 2016
Test Result - PASS
Operation Per Second: 4.65205e+006
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Mon Feb 08 20:15:51 2016
Cache Test
Start Time: Mon Feb 08 20:15:51 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 6144
Cache Size Test Passed!!!
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
AVX Test
Module Version: 1.0.11.64b.W
Test Result - PASS
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
End Time: Mon Feb 08 20:15:52 2016
IMC Test
Start Time: Mon Feb 08 20:15:52 2016
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 8.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
PCH Test
M...
ppara5
