16851 Discussions
IPDT , IMC would not run and failed, so found how to allow IMC to run successfully
RCarb3
THIS PROBABLY WON'T WORK FOR EVERYONE!
Have been running IPDT out of curiosity, my desktop does not have any problems. Program ran previously with all tests passed, Updated IPDT and had IMC test fail, tried old program and IMC failed there too. Memory tests show no problems. So this is just my observation that may help others.
Here is my machine, Alienware Area 51 original, not overclocked, running Windows 7 SP1 64-bit.
Version: 5.80.20171018
Time Stamp: 2018/10/30 20:42:49
Operating System: 6.1-7601-Service Pack 1
Number of processors in system: 1
Current processor: # 1
Active cores per processor: 6
Disabled cores per processor: 0
Processor Name: Intel(R) Core(TM) i7 990X Extreme Edition CPU @ 3.47GHz
Type: 0
Family: 6
Model: 2C
Stepping: 2
Revision: 13
Maximum CPUID Level: B
L1 Instruction Cache: 6 x 32 KB
L1 Data Cache: 6 x 32 KB
L2 Cache: 6 x 256 KB
L3 Cache: 12 MB
Packaging: LGA1366
Enhanced Intel SpeedStep(R) Technology: Yes
MMX(TM): Yes
Intel(R) SSE: Yes
Intel(R) SSE2: Yes
Intel(R) SSE3: Yes
Intel(R) SSE4: Yes
Intel(R) AES-NI: Yes
Intel(R) AVX: No
Enhanced Halt State: Yes
Execute Disable Bit: Yes
Intel(R) Hyper-Threading Technology: Yes
Intel(R) 64 Architecture: Yes
Intel(R) Virtualization Technology: Yes
Intel(R) VT-x with Extended Page Tables: Yes
System Graphics: Add-in Graphics
Expected Processor Frequency: 3.47 GHz
Reported Processor Frequency: 3.60 GHz
Expected System Bus Frequency: 133 MHz
Reported System Bus Frequency: 133 MHz
When the IMC test tries to run it fails and there is nothing in the log, the IMC section is missing.
So tried many things, but eventually found that running IMC.exe, dated 10/4/2018, in Windows 7 compatibility mode, allowed the exe to run and pass all tests.
Here are the results running IMC in compatibility mode:
--- IPDT64 - Revision: 4.1.0.31
--- IPDT64 - Start Time: 10/30/2018 4:44:00 PM
CPU1
Genuine Intel CPU Test
Module Version: 1.0.16.32b.W
Start Time: Tue Oct 30 16:44:00 2018
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Tue Oct 30 16:44:00 2018
Total Time: seconds: 0
CPU1
CPU Brand String Test
Module Version: 1.0.20.64b.W
Test Result - PASS
Expected: Intel(R) Core(TM) CPU @
Detected: Intel(R) Core(TM) i7 CPU X 990 @ 3.47GHz
Intel(R) Core(TM) processor detected..!!..
CPU1
Cache Test
Module Version: 1.0.16.64b.W
Start Time: Tue Oct 30 16:44:01 2018
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 12288
Cache Size Test Passed!!!
End Time: Tue Oct 30 16:44:01 2018
CPU1
MMXSSE Test
Module Version: 1.0.21.64b.W
Test Result - PASS
DetectUtils64 DLL Version - 1.1.2
--- Determining MMX - SSE capabilities ---
..MMX is supported on this CPU..
..SSE is supported on this CPU..
..SSE2 is supported on this CPU..
..SSE3 is supported on this CPU..
..SSSE3 is supported on this CPU..
..SSE4.1 is supported on this CPU..
..SSE4.2 is supported on this CPU..
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
CPU1
IMC Test
Module Version: 1.0.12.64b.W
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 12.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
CPU1
Parallel_PrimeNum_i7 Test
Module Version: 1.0.0.9
Start Time: 10/30/2018 4:44:02 PM
Test Result - PASS
Module Math_PrimeNum.exe Completed - Pass
Prime Number Generation Test
Module Version: 1.0.19.64b.W
Start Time: Tue Oct 30 16:44:02 2018
AVX is NOT supported in your OS
Test Result - PASS
Operation Per Second: 506500
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Tue Oct 30 16:44:22 2018
Total Time: seconds: 20
End Time: 10/30/2018 4:44:22 PM
CPU1
Parallel_FP_i7 Test
Start Time: 10/30/2018 4:44:22 PM
Test Result - PASS
Module Math_FP.exe Completed - Pass
Floating Point Test
Module Version: 1.0.18.64b.W
Start Time: Tue Oct 30 16:44:22 2018
FMA3 not supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 53.235
Error: 0
--- Floating Point Test Passed!!!---
End Time: Tue Oct 30 16:44:42 2018
Parallel_FP_i7
End Ti...
