16836 Discussions
ITBM driver not available
ili_a
hi
i have an dell inspiron 5567 with intel core i7 7500U cpu
i want to active turbo boost but when i run the app, it says ITBM driver not available exiting the app
i attached the configuration file here
hope to help me
David_G_Intel
Hello ili_a
Intel Turbo Boost Technology is a way to automatically run the processor core faster than the marked frequency. The processor must be working in the power, temperature, and specification limits of the thermal design power (TDP). This results in increased performance of both single and multi-threaded applications. There is no need to install any software or application to support Intel® Turbo Boost Technology.
You can typically enable or disable through a switch in the BIOS. Refer to your laptop manufacturer for BIOS options to enable and disable Intel Turbo Boost Technology.
David G
Intel Customer Support Technician
David_G_Intel
Hello ili_a
David G
David_G_Intel
We're glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will proceed to close it.
David G
