16791 Discussions
If Linux OS can run on Atom Z8000 series cpu?
JGuo11
In datasheet, it shows that win8.1 and android can run on z8000, and how about linux?
IUman
Hello JackyGuo,
Thank you for joining the Intel communities.
In this case, most systems are able to run Linux* so I don't see the reason why not running Linux* with this unit; however, if Windows 8.1 and android are the only ones showing in the datasheet is because those are the ones that Intel validated, so at this point I suggest waiting for someone else to POST here the experience they have had when they installed Linux* with this product.
Best wishes,
Ivan
