16790 Discussions
Inconsistent booting and ability to stay on
swanny
Just built two towers, using 12400's on an Asus B660 mATX board. Both consistently start (fans), but there is inconsistent video/USB power output (front and back panel). When I tried to put windows media on them it got halfway through the final check twice, one time the tower completely crashed, and the other time it said there was an error and to redo the process, so it took me back to the install screen then crashed almost straight away. This seems like a processor issue to me, though I can't be completely sure so any suggestions would be much appreciated.
P.S. it took me about two hours to get them to stay on long enough to get as far as the windows install process.
Swanny
AlHill
One processor faulty is possible.  Two, on two different motherboards is unlikely.
Update your board's bios, install the chipset inf, and try again.  Also, state clearly your configuration, power supply, memory, etc.
swanny
It's two 12400's on the two of the same ASUS mATXB660s. It's 8*2 silicon power ddr4 at 2666mhz with two EVGA 450 bronze psus. the systems are identical.
kind regards,
Ben
Alberto_R_Intel
swanny, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
When did you purchase the Intel® processor? (For warranty purposes)
Did the two towers you described ever work fine before?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this issue?
Which Windows* version are you using?
What is the model of the memory RAM that you are using? Please provide the part number and quantity of sticks being used.
What is the model of the HDD/SSD being used?
If you can access Windows*, please attach the SSU report so we can verify further details about the components in your platform, check all the options in the report including the one that says "3rd party software logs":
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
Alberto_R_Intel
Hello swanny, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello swanny, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
