16804 討論
Installation of Intel MPI Library 2018 Update 1 is hanging at first step. No msiexec.exe can be found in Tas Manager. Any Suggestion?
bszoc
初學者
2,782 檢視
​OS: Windows 7 Enterprise Service Pack 1
Company HP 840 Workstation in Intranet.
Intel Xeon CPU E5-2687W v4 @ 3.00 GHz (2 processors)
Intel MPI Library 2018 Update 1 for Windows
Dear community,
I cannot install MPI Library (Intel MPI Library 2018 Update 1; w_mpi-rt_p_2018.1.156.exe). After starting installation, the process is hanging at step 1 (Installing component 1 of 11: Intel Parallel Studio XE 2018 Common Files) with no further progress. I work with a company workstation HP Z840, Processor: Intel® Xeon® CPU E5-2687W v4 @ 3.00 GHz (double processors).
Looking at the last line of the install log file, I can see that the installer is hanging on the .msi installer files:
[---- 2019.01.28 14:42:20.229 00000dec] [MSI processing]: INFO: request to install msi: C:\Users\******\Downloads\Intel\w_mpi-rt_p_2018.1.156\installs\parallel_studio_xe\041\studio_common_libs
After this, the installer hangs. The .msi's it tries to install are found in C:\Users\******\Downloads\Intel\w_mpi-rt_p_2018.1.156\installs\parallel_studio_xe\041\, but they cannot be run on their own (it tells me to run them through setup.exe).
Windows Installer is checked: there is no msiexec.exe in task manager.
Any suggestion how to install Intel MPI Libarary 2018 Update 1? Thank you in advance!
0 積分
2 回應
Amy_C_Intel1
員工
2,017 檢視
Hello bszoc, Thank you for posting on the Intel® Communities. To help you with your question, please post your inquiry in the https://software.intel.com/en-us/forum. The support for this software is handled there. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
nkhan8
初學者
2,017 檢視
I am also getting same issue..Is this resolved?
回覆
