17060 Discussions
Installing HAXM fails
CMiso
Hello
I am trying to install HAXM on my Lenovo U410 with a clean Windows 8 install. It has worked before on Windows 7.
Intel Vtx is enabled in BIOS. I downloaded the HAXM installer with the Android SDK manager. When I run the executable I get the following error: "This computer does not support Intel Virtualization Technology..."
When I disable Vtx in BIOS and run the .exe I can assign an amout of RAM for HAXM, when it finishes I get this error: "This computer meets the requirements but is not enabled..."
This is the CPU: I7-3517U. The intel page says it supports vtx
http://ark.intel.com/products/65714/Intel-Core-i7-3517U-Processor-4M-Cache-up-to-3_00-GHz ARK | Intel&# 174; Core™ i7-3517U Processor (4M Cache, up to 3.00 GHz)
Running the Processor Identification Utility says it does not support Intel Virtualization Technology.,v
Very strange. Any ideas?
Silvia_L_Intel1
Chisonne,
Have you tried to do a BIOS update on your laptop in order to update the processor code?
However, please let me try to find some information for you. I will keep you posted.
Regards.
CMiso
Sylvia
Thanks for your help.
As you said i suppose the problem is with Windows 8.
I had other troubles with the OS so I installed Windows 7 again. At least everything works fine now.
regards
Charlie
Silvia_L_Intel1
Charlie,
So it looks like it is a compatibility problem with Windows 8. I'm glad to know your system is working fine running Windows 7.
Regards.
GCypr
Hello Sylvia,
I have the same processor (I7-3517U) and I'm experiencing a very similar issue on Windows 8.1.
I have tried installing both HAXM version 1.0.6 (R3) and version 1.0.7 (R3 hotfix for Windows 8.1). However, no matter if I enable or disable Intel Virtualization on BIOS I always get the "This computer meets the requirements for HAXM, but Intel Virtualization Technology is not enabled" error.
I don't have Windows 7 and would appreciate a fix to this issue.
Silvia_L_Intel1
Gabrielcs, please let me have the model number of your computer? Are you running the latest BIOS version available for it?
GCypr
Hi Sylvia, sorry for the delay. I was having login issues.
Here's my computer/BIOS info:
  • Computer Maker: LG Electronics
  • Computer Model: Z460-G.BG51P1
  • BIOS Type: Phoenix Technologies Ltd.
  • BIOS Version: ZDCRSF81
  • BIOS Date: 10/04/2012
On my product's http://www.lge.com/br/suporte-produto/lg-Z460-G.BG51P1-7446 webpage there's no BIOS update for Windows 8 (or Windows 8.1). There's only a BIOS update for Windows 7 that always crashes with an installation error. I've contacted LG support and they've sent me the link to the Korean http://www.lgservice.co.kr/cs_lg/download/DriverSoftwareListCmd.laf?divice=WEB&categoryCode=C001005&daepyoModelId=z460&modelId=&sort=regdate&os=OS18&productClass=&opneProductClass=,SW09,SW02 webpage with drivers for all the Z460 models. However, there was no driver update for the BIOS on that page.
How should I proceed? Thanks in advance.
Silvia_L_Intel1
Gabrielcs, I was marking some research and it looks like HAXM is incompatible with the Hyper-V feature of Windows 8. You would have to disable Hyper-V.
To disable Hyper-V:
  • Go to Programs and Features in Control Panel
  • Click "Turn Windows Features On or Off" in the left navigation area
  • Find Hyper-V and clear the check mark.
Here's a thread if you need additional information.
http://superuser.com/questions/634630/virtualization-not-enabled-in-windows-8-but-enabled-in-bios http://superuser.com/questions/634630/virtualization-not-enabled-in-windows-8-but-enabled-in-bios
Silvia_L_Intel1
Chisonne,
The I7-3717U supports VTX, so the problem could be when running HAXM under Windows 8.
I recommend you to check if you have the 1.0.6 (R3) version of HAXM. You will be able to find it on the following link: http://software.intel.com/en-us/articles/intel-hardware-accelerated-execution-manager http://software.intel.com/en-us/articles/intel-hardware-accelerated-execution-manager
Regards.
