MY PC
Samsung 1TB 9100
corsair i cue line 360
corsair dominator titanium 6000mhz DDR5
Gigabyte Intel Z790 AORUS PRO X PCIe 5.0 ATX Motherboard
asus TUF gaming 1000w power supply 3.0
gigabyte 5080 master ice
Hi daniel337337,
- When did the issue start?
- What are the troubleshooting steps that you tried so far other than BIOS update?
- Did you overclock the processor?
- Did you apply Intel Default Settings?
- Is there any physical damage?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
start day 1 apply Intel Default Settings no damage on
Hi daniel337337,
Thank you for the feedback. I've sent an email to your active email address for the next step of the process.
Please check both your Inbox and Spam folder for my email, and once received, kindly acknowledge it.
Archie D.
im going to go AND tomorrow take the intel cpu out ALL THAT MONEY AND IT DOESN'T WORK
Hi daniel337337,
Thank you for the feedback. I understand your concern and I respect your decision for this.
If you need further support, please let me know or respond to the email that I sent you. Thank you.
Archie D.
need to know what wrong with the CPU
Boxed Intel® Core™ i9 processor 14900K (36M Cache, up to 6.00 GHz) FC-LGA16A
Hi daniel337337,
Intel customers using 13th and 14th Generation Intel® Core™ i7 and i9 desktop processors have reported frequent OS and application hangs and errors. These issues mainly affect enthusiast/gaming systems with commercial ODM motherboards and OEM workstations. Intel has identified the problem as a Vmin Shift Instability in the IA core's clock tree circuit, which is susceptible to reliability aging under high voltage and temperature. This can cause a duty cycle shift in the clocks, leading to system instability.
Archie D.
just got email from intel RMA SAY my email name my shipping address is blank
Hi daniel337337,
Thank you for the feedback. Please reply back to the email that I sent you if you wish to proceed with the warranty claim.
Archie D.
