16983 Discussions
Intel Core 2 Duo T6500 supporting OS
I am purchasing a laptop from Dell, model # S540513IN8 - Dell Inspiron(TM) 1440 Laptop. With this system the OEM is giving Vista Home Premium 64 bit SP1 edition. Now I am interested in using 32 bit OS only. Will this processor be able to support the 32 bit OS and if yes then will I be able to run all the drivers specific to 32 bit OS?
Hi there,
Most Intel® Processors are designed to support both 32bit and 64bit platform. However not all processors will support 64bit platform, but all will support the 32bit platform.
So you need not worry, if you say the system you are buying will come with Vista 64bit version, hence the processor supports both 32 bit and 64 bit platforms.
However I cannot find any information about the T6500 processor. May be you have mis-typed the model.
If it's the T5600 instead, then you may find the processor details on this link: http://ark.intel.com/Product.aspx?id=27254&processor=T5600&spec-codes=SL9SG,SL9SP,SL9U3,SL9U7,SLA4E
If you want to know more about other Intel processors or another intel technology you can use this link and enter the specific product and you will find the information: http://ark.intel.com
For the drivers, you will need to contact the manufacturer of the system to get more support. Operating system drivers are not related to processor. It has nothing to do with the processor. Please contact Dell to know more about drivers availability for 32bit versions of operating system.
FYI: Under 32bit operating systems you cannot use more that 3.5GB - 4GB memory.
Hope this will be useful.
Cheers.
Thanx for your prompt reply! . The processor that I mentioned is indeed correct although even I did'nt find out this processor on intel site. However, you can go through this product from the site http://www1.ap.dell.com/in/en/home/laptop-inspiron-14/pd.aspx?refid=laptop-inspiron-14&s=dhs&cs=indhs1&ref=homepg http://www1.ap.dell.com/in/en/home/laptop-inspiron-14/pd.aspx?refid=laptop-inspiron-14&s=dhs&cs=indhs1&ref=homepg.
I believe your answer will be helpful to me. May be you can help me that the laptop which I am going to purchase is the good one. Please suggest. My basic use for laptop will be to develop applications as I am software engineer and browse internet.
Thanx once again!
Amit
John_S_Intel
The Intel® Core™2 Duo Processor T6500 (2M Cache, 2.10 GHz, 667 MHz FSB) will support the 32-bit, Windows*-based operating systems.
John S.
Intel Customer Support
*Other names and brands may be claimed as the property of others.
I need to know if the T6500 will support virtual Windows XP on Windows 7. Thanks
John_S_Intel
As I understand it, you'll need a processor that supports virtualization in order to take advantage of the XP* compatibility mode within the soon-to-be-released Windows* 7 operating system. (source: http://blogs.zdnet.com/hardware/?p=4263 http://blogs.zdnet.com/hardware/?p=4263)
The Intel® Core™2 Duo Processor T6500 does not** feature Intel® Virtualization Technology. (source: http://ark.intel.com/Product.aspx?id=39311&code=t6500 http://ark.intel.com/Product.aspx?id=39311&code=t6500)
With that said, the T6500 will not** support XP mode on Windows 7, but you might double-check the hardware (CPU) requirements from Microsoft* once Windows 7 is acutally released. Intel should have more information available once the new Microsoft operating system launches.
** this is a correction - Originally, I had mistakenly stated that the T6500 supports VT. I used ark.intel.com as my reference, but the information turned out to be incorrect. The processor feature information for the T6500 has since been been corrected. VT is actually not a feature of the T6500. I am sorry for any incovenience this may have caused.
John S.
Message was edited by: JohnS
Apart from the fact that the processor does not appear on the following site
http://ark.intel.com/ProductCollection.aspx?familyID=26548 http://ark.intel.com/ProductCollection.aspx?familyID=26548
It turns out theres a problem with what the website says
And what the Processor Identification Utility tells me
John_S_Intel
I am sorry, I was mistaken. Thanks for bringing this to my attention.
The T6500 does not support VT. I used ark.intel.com as my reference, but as you pointed out, the information turned out to be incorrect. The processor feature information for the T6500 contained within ark.intel.com has been corrected. VT is actually not a feature of the T6500.
The processor identification tool is correctly reporting that VT is not a supported feature of the Intel® Core™2 Duo Processor T6500.
John S.
John,
Well I DID buy a computer with a T6500 processor. Fortunately I have not broken the seal yet and am able to return it if I want.
This is still on the Intel Web site, though. See this link: http://ark.intel.com/Product.aspx?id=39311&code=t6500 http://ark.intel.com/Product.aspx?id=39311&code=t6500)
Thanks for keeping me posted (before I opened the new computer box!)
Gini
John_S_Intel
The web site changes were made during the day yesterday, but they did not go live until sometime last night (automated process). The web site changes are now live. See the link: http://ark.intel.com/Product.aspx?id=39311&code=t6500 http://ark.intel.com/Product.aspx?id=39311&code=t6500
John S.
Please note that at least one other area of the intel.com site still says that the T6500 supports Intel® Virtualization Technology.
Follow the URL below to go to the "Processor Spec Finder" page for the "Intel® Core™2 Duo Mobile Processor" and filter on "Intel® Virtualization Technology":
http://processorfinder.intel.com/List.aspx?ParentRadio=2643%2c3040%2c2967%2c2278%2c2883%2c2304%2c2848%2c826%2c942%2c58%2c3008%2c&ProcFam=2643&SearchKey= http://processorfinder.intel.com/List.aspx?ParentRadio=2643%2c3040%2c2967%2c2278%2c2883%2c2304%2c2848%2c826%2c942%2c58%2c3008%2c&ProcFam=2643&SearchKey=
The T6500 is returned in the filtered list of processors that, supposedly, support VT. This would seem to conflict with your statement that the T6500 does not support VT.
If you click on the T6500's sSpec# link, in the search results, you see the resulting spec also says that this cpu supports VT:
http://processorfinder.intel.com/details.aspx?sSpec=SLGF4 http://processorfinder.intel.com/details.aspx?sSpec=SLGF4
I hope you can resolve this conflict and have someone review your site to validate all posted processor spec's. Such inaccuracies and inconsistencies make it hard to make informed decisions. Further, if corrections are made, please make special note of them so that customers making purchasing decisions can take the corrected information into account before making purchases.
John_S_Intel
Thank you for bringing this to my attention. I've got a request in to correct the error. The records for the T6500 in processor spec finder should be fixed sometime today.
John S.
Hi All!!
Till 20th July 2009 Intel was saying like its T6500 processor supports Intel Vitualization .By Seeing that only I had purchased Thoshiba Laptop L510 powered by Intel T6500 processor..I was looking for the model which supports virtualization..I was really need of it.. But as of now updated web page Intel T6500 is not Supporting Intel Virtualization.Intel is such a big company , I never thought that , It may cheat people by providing such a false information. Since I had purchased the laptop that it supports the Feature, Now its became no use for me..So regarding this Intel responsibility to replace my Laptop with a laptop powered by Virtualisation enabled processor. or Can I take any Legal action against Intel...I hope many people come up and supports me in this regard..
Thanks in Advance,
Ninge Gowda,
Bangalore,
India,
Mobile: 91-9663697588
Home:9180-2664866
off: 9180-66604840
Mail: mailto:ningeg@gmail.com ningeg@gmail.com
