16794 Discussions
Intel® Core™ Ultra 9 Processor 275HX keeps overclocking
RvL_Asd
Hi all,
Got a laptop with the Intel® Core™ Ultra 9 Processor 275HX. Win 11, RTX5090, 192GB.
Need some help here.
When the laptop is on power supply (so not working on the battery) the CPU keeps running above 2.7GHz. It overclocks above 3GHz all the time and runs even in the 4GHz when it is idle...the GPU is switched off. The temperature joins up to 70-85 degrees Celcius, which I guess makes sense with the overclocking. The fan also joins the party by 50-60%.
When the laptop is off the power cable and the battery is used, the CPU goes directly to 300-800 MHz which I would expect when idle. From there it hangs around 1.5 GHz. As result temperature drops to around 40-45 and fan 35-40%. Also expected.
BIOS, Intel Software, Control Center and Windows 11 don't have the option to stop the overclocking. Even in Power Control in Windows where you can parameter the usage of the CPU (0-100%) is totally ignored by the CPU. Control Center has the option Performance, Entertainment and Quiet mode. On all three opties and when on power cable the CPU doesn't go to default 2.7 GHz setting either.
The answer from the store where I bought the laptop stated 'Oh, it is a powerful chip, it just wants to perform'. Uh-uh.
Anyone an idea how this overclocking is happening? Better yet, how to stop the CPU for doing so until instructed (e.g. in Turbo modus, if there is any).
Let me know if more information is needed.
Cheers,
Robert
pressed_for_time
Valued Contributor II
You should contact the support department of the manufacturer of your laptop to verify whether this is or is not expected behaviour. And if the system is working as designed whether there is anything they can do to address the issue you are seeing.
RvL_Asd
@pressed_for_time thank you for your reply. Indeed I did contact them, hence the answer they provided placed in my post. Unfortunately, no solution came out of it and therefor I try the community.
@all members of this community, side note: interesting enough the emailaddress I use just for this community has been used to log in for a Microsoft Account. This was done only a couple of hours after I posted my message. Make sure you have 2FA activated for your Microsoft Account.
Brokeyboy
that is just turbo boost man nothing to worry about
Jasko-PL
ASUS G615LW - with core 9 275HX ultra.
Tried everything.... AMI Bios dosent give much options to OC/UC. Tried Windows plans, and also ASUS Armory plans. Might help, but not. Las option was Intel XTU, and... That gives me a small chance! YES! Even with "X" processors cant be OC/UC. On of options to change is Turbo Boost Short Power MAX Enable/Disable - Make Disable. Turbo Boost Power MAX - from 1W to Unlimited - Basic was 175W, Changed it do MAX = 70W. An its end. Nothing more to change. Asking WHY ??? Why i want UC mi core 9 ? Beacuse even if i do nothing, CPU has 50-60C.
On Windows starts, gots 3 THERMAL FLAGS !!! TT+PLT (PL1+PL2) + PMAX T ( CPU Utilization 18-20% ) Package TPM = 83% Package TDP 54W, and all on Power Limits on 70W max. Tried to capture SS on al flags but only TT was on when make SS.
When i use only ASUS Armory Create plans without XTU, then Package Temperature is critical!! 102-104C. Makes all FLAG ON, and drastically degrades functionality. No matter on with one plan i chose. Silent, performance, Turbo. In Silent is extremely dangerous! Because, Armory Create even if TMP is more than 90C trying keep fan low as possible.
One of solution was use XTU as service, but... dunno why watchdog mode is false, and cant turn it on.
I use specific programs, with one use both CPU and GPU, to make colossal calculations, and virtualization. But, almost 80% job is done by GPU, with one has only 70-80C on FULL LOAD. ( 99% ) On CPU load on same job is about 12-18% and 101-104C ( + all flags on throttling )
 Should i contact ASUS? This unit got only 1 month.
