Avisos
16855 Discusiones
Intel Core i5-6600K 3.5GHz / Asus Z170-A Motherboard reboot failure
Empleados
5.356 Vistas
On Saturday 1/4/17 the Computer failed to restart from a software reboot
It would not complete POST (stopped before the normal single Post bleeped) or display anything to screen and I could not enter BOIS etc.
My computer comprises of (All new 19/12/2016)
Intel Core i5-6600K 3.5GHz Boxed retail
Corsair Vengeance LPX 16GB (4x4GB) DDR4 DRAM 3000MHz C15 Memory Kit – Black
Corsair VS Series 550 Watt VS550 Power Supply
LiteOn iHAS124 24X Internal DVD Writer with SATA – OEM
Samsung SSD 850 Pro 256GB
Corsair Hydro Series H45 Performance Liquid CPU Cooler
Using on board Graphics
Fault observations
On board LED's
3 Design LED's ON ,Standby LED Lit Green and steady
LED Turn on sequence >CPU LED on then quickly off > Dram LED On then Off Quickly
Then halt to progress
My diagnosing testing work
Tested power supply
restore BIOS setting by shorting CLRTC jumper
Removed all Hard and CD drives etc. so no externals
Still the same
I Installed an old graphic card then it would Fully POST and work normally. On removing the old graphic card to use Just the iGPU HD Graphics 530 then the fault comes back.
Q) can a CPU i5-6600K partially work, the HD Graphics 530 part fail and the rest work OK ?. As Asus customer care are trying to claim its Intel fault and I should replace the CPU but i think its the motherboard.
0 kudos
10 Respuestas
Empleados
4.022 Vistas
PeterBrough, thank you very much for joining the Intel® processors communities.
To answer your question, yes, there have been a few cases where the graphic part of the processor fails and the rest of the features work fine.
According to the information you gave us above, it says the memory is running at 3000MHz and that speed is too high for the processor to work with it, the processor supports DDR4-1866/2133, DDR3L-1333/1600 @ 1.35V, so please make sure the memory is running at 2133MHz tops:
http://ark.intel.com/products/88191/Intel-Core-i5-6600K-Processor-6M-Cache-up-to-3_90-GHz?q=6600K http://ark.intel.com/products/88191/Intel-Core-i5-6600K-Processor-6M-Cache-up-to-3_90-GHz?q=6600K
Now, for this scenario what we recommend to do will be to test the PC with the very basic configuration. Please test it with the power supply, processor, just one memory stick at 2133 MHZ, connected to the monitor with no hard drive and no video card, then turn it on, we should get a boot agent error or the BIOS of the board. If we get that then you can connect the hard drive and add the rest of the memory sticks one by one.
Please let us know the results of trying the steps above.
Any further questions, please let me know.
Alberto
Empleados
4.022 Vistas
Thanks for your response Alberto
To be honest I brought the memory because they were on the Asus Z170 - supported memory list and the price. I did not set the memory speed manually I loaded the default BIOS settings, and after testing I used the Asus utility to optimise the system, it has the MaxBandwidth as 2132MHz. and it was working well for 4 months but I don't know what speed that was at but it was very stable until it stopped working
With regards to your recommend testing of the PC I had done that, with the exception I did not know what the memory was set at. When I tested my PC it would not post without an dedicated GPU. I will try again tomorrow making certain of the memory speed.
Unfortunately, I do not have access to another compatible CPU or motherboard as I would like to try swapping them over as well.
Now I have your info I will try again with an eye on memory speed and will let you know of the progress
Kind Regards
Peter
Empleados
4.022 Vistas
PeterBrough, you are welcome.
And yes, if after trying the steps above the problem persists then the next thing to do will be to swap parts, that is one of the last steps to do because sometimes that option is not available. So, please take your time and test the PC with you get the chance and let us know the results. Just to let you know the board might be able to run at a higher memory speed, but the thing is that the memory controller is located on the processor, so the processor is the one that indicates which memory will be fully compatible. If the memory RAM is running at 2133MHz then the processor should work just fine with it.
Alberto
Empleados
4.022 Vistas
Alberto
Thanks for your continuing support it always nice to have fresh thoughts on a problem it also stops you going mad.
I went back to fault finding, firstly I went to the Asus BIOS tuning program in windows 10 and removed any overclocking settings, rebooted and went into BIOS and memory is running at 2132.1MHz on the default settings
Turned off mains
Removed the old graphic card (AND Radeon HD 6670)
Disconnected Hard and SSD drives
Removed all memory sticks and replaced 1 stick in default slot DIMM _A
Connected Monitor to built-in motherboard VGA port
Crossed fingers and restarted
No Luck
Just as before, it would not Post fully but you could see some progress through the on-board LEDs, it checked CPU OK > Dram OK, then halt, no beep/s, no display output on any VGA, HDMI or DISPLAY port (if all was well it would make 1 beep and then display ASUS on screen then go to bios or windows)
So, no communications with the on-board Intel® HD Graphics 530 that's on the CPU.
The question is what's at fault the "Asus" Motherboard or the "Intel® Core™ i5-6600K Processor" that contains the on-board Intel® HD Graphics 530?
I don't have access to another motherboard or CPU but if I did, could swapping them over cause damage. As I don't know what's at fault how do I ask for a warranty replacement as each may blame the other.
Help!!!
Kind regards
Peter
Ps replacing old graphic card "AND Radeon HD 6670" and it reboots
Empleados
4.022 Vistas
PeterBrough, You are welcome. Thank you very much for providing those steps and the results after trying them.
There is no problem to try to swap parts, it will not caused any damage, that is actually one step that we recommend to identify if the problem is the processor or the board, just make sure if you have the option to do that, to confirm that the parts are fully compatible. You can do that by checking the compatible products for the board or processor depending on the model. As you mentioned above, it is kind of difficult at this point to make sure if the problem is the processor or the board, based on some cases we have, normally the problem is related to the board, but that is not for sure.
I sent you a private message, please verify your inbox.
Alberto
Empleados
4.022 Vistas
PeterBrough, I just wanted to check if you received the private message and if you need further assistance on this matter?
Alberto
Empleados
4.022 Vistas
HI Alberto
Using the information and links in your private message I have started a return under warranty, the CPU is being picked up today. When i have it returned i shall do a swap and we will know the answer to "what's at fault the "Asus" Motherboard or the "Intel® Core™ i5-6600K Processor" .
I must say that Jacqueline at Intel customer support and your good self have been most helpful.
Thanks again
Kind regards
Peter
Empleados
4.022 Vistas
Hi, PeterBrough, you are welcome, perfect, excellent, it is great to hear that you will be able to replace the processor, once you get the chance please let us know the results of testing the new unit.
Alberto
Empleados
4.022 Vistas
HI Alberto
Today was the day I got my under warranty replacement CPU delivered from Intel via "DHL express service" all at no cost to myself, it was a bit delayed due to Easter bank holiday, my CPU was picked up from my home address and returned to Intel following day, Intel started the return to me following day, overall I must say a very good service, now I know why it pays to buy a boxed CPU and not OEM.
So to testing it.
I removed the old graphic card (AND Radeon HD 6670) put the replacement CPU into my computer crossed my finger and turned on the power and pressed the start button, it booted up without further problems. After going through the BIOS settings just to make checking all was well, it could read Intel® HD Graphics 530 that's on the CPU.
I did a burn in test using the "Intel Processor Diagnostic Tool 64bit" a run taking 2 Hrs and it Passed all tests.
I now know the answer to "what's at fault the "Asus" Motherboard or the "Intel® Core™ i5-6600K Processor" .it was the "Intel® Core™ i5-6600K Processor"
Thanks to everyone for the support and Help
Peter
Empleados
4.022 Vistas
Hi, PeterBrough, You are welcome. Excellent, it is great to hear that the problem got fixed by using the new processor, it should work from now on with no problems.
Any other inquiry, do not hesitate in contact us again.
Alberto
Responder
