16800 ディスカッション
Intel Core i5-661 driver?
MTann1
ビギナー
3,635件の閲覧回数
Where can I find it? I've been going up and down through the download center and every time I think I've found it it points me to Intel's stupid Download Utility that never works. Why is it so damn hard to find a manual driver setup? ._.
0 件の賞賛
5 返答(返信)
Allan_J_Intel1
従業員
2,310件の閲覧回数
Thanks for joining the processor community.
I am sorry to hear that you have had issues with the Intel web site trying to download Intel drivers.
As per processor specifications, this is Intel® HD Graphics first generation. The driver is available at this URL: https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3231 Intel® Download Center
Please filter by operating system and try to install the driver when it finishes downloading, to verify that your system will accept it.
Allan.
MTann1
ビギナー
2,310件の閲覧回数
I got the Win7 64bit version since there isn't one for Win8 and it doesn't work.
Allan_J_Intel1
従業員
2,310件の閲覧回数
If you currently installed Windows 8 on Intel® HD Graphics first generation, the driver for Windows 7 will not work.
Win8 drivers for your graphics controller are provided by Microsoft through Windows Update tool.
See the following URL for operating system support: http://www.intel.com/support/graphics/sb/CS-034343.htm Graphics Drivers — Supported operating systems
Allan.
MTann1
ビギナー
2,310件の閲覧回数
Ok I've seen it, now what?
Look my problem is that I want to disable my integrated graphics cause I having issues with a program which I think may be running on Intel graphics instead of my GeForce graphics card. But I have no way of doing that since it's not showing up in the Device Manager. I thought the cause of it might be a driver I'm missing. I already have the latest motherboard driver, don't I need one for the CPU as well?
Allan_J_Intel1
従業員
2,310件の閲覧回数
Sorry to hear you still have same problem. You need to check with your motherboard maker for any BIOS settings in order to disable on-board graphics. However, once you installed an external video card, the on-board graphics solution gets disabled electronically.
Allan.
返信
