16771 Discussions
Intel DG95RY Motherboard Compatibility with intel pentium dual core e6600 3.06ghz processor spec code: SLGUG
I am planning to upgrade my pc with an intel pentium dual core e6600 spec code: slgug 3.06 GHz processor my motherboard is intel DG965RY, i just want to reconfirm the processors compatibility with my motherboard for when i use the compatibility tool it shows 2 results one for the core 2 duo processor and one for the dual core, as i select the dual core the compatibility table shows he result for the core 2 duo although i selected dual core.
The board is not compatible with the Intel processor E6600. You can get a full list of Intel* processors compatible with the board:
http://www.intel.com/support/motherboards/desktop/dg965ry/sb/CS-026603.htm?wapkw=%28DG965RY%2c%29 http://www.intel.com/support/motherboards/desktop/dg965ry/sb/CS-026603.htm?wapkw=%28DG965RY%2c%29
Please bear in mind that this product is no longer under support. Intel provides further information on your particular product at the following link:
http://ark.intel.com/products/22637/Intel-Desktop-Board-DG965RY http://ark.intel.com/products/22637/Intel-Desktop-Board-DG965RY
