17285 Discussions
Intel Driver And Support Assistance not working.
trev123
As in the title.
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Windows 11 is the new Vista]
trev123
Here is the scan file.
ClariceStarling
Valued Contributor II
A couple of people have said that.  If you clear your cache and reboot, or use another browser, it will probably work!
