16806 Discussions
Intel® Driver & Support Assistant - Sorry, something went wrong while trying to scan.
JimBillows
This is an issue with the chipset drivers I assume.
I have tried uninstalling with the tool and without and reinstalling.
As soon as I open the assistant I get this warning.
This device is erring:
Resource Hub proxy device
This device is currently waiting on another device or set of devices to start. (Code 51)
Dependencies:
PCI\VEN_8086&DEV_7ACE&SUBSYS_00000000&REV_11\3&11583659&0&AA
I need to update the proper drivers.
Please help me fix the assistant.
Mike_Intel
Hello JimBillows,
For us to further check this, please help provide the following details:
  1. Are you using a laptop or a desktop?
  2. Please share the brand and model of your system.
  3. What are the Intel controllers that you want to update?
  4. Can you share a screenshot of the issue?
Michael L.
JimBillows
1. Desktop
2. gigabyte Z690 AORUS ELITE AX DDR4 (rev. 1.x)
3. Not sure the assistant stated 3 drivers need to be updated but does not specify which ones.
4. Attached.
Mike_Intel
Hello JimBillows,
Thank you for the update.
There is a lot of factor why the Intel® Driver & Support Assistant to have error in scanning your system. It could be the cache of the browser, the internet or updates. On this case, you can manually download the drivers and update your system.
Here is the link of your motherboard and the available drivers. If you have further questions, please contact them. Thank you|:
https://www.gigabyte.com/Motherboard/Z690-AORUS-ELITE-AX-DDR4-rev-1x/support#support-dl-driver
Michael L.
JimBillows
We know where to download drivers.  We would like to get the assistant fixed. Is that possible? Why would we leave it broken?
JimBillows
Do you not support your software?  We would like to get this fixed.  We only like to install and update the drivers we need. Is there a problem? Also from your response all of the information was included in my first post. Why ask for more info if you were going to refuse to help fix your software?
LeonWaksman
Hi @JimBillows
The Intel DSA is not very reliable tool. If you want to make it working again you need first to uninstall it using Intel DSA Uninstaller
Once IDSA is uninstalled, download and install the latest version.
Leon
VARADHARAJAN
Valued Contributor II
@JimBillows
You  install the intel serial IO driver and download it from the below site
Intel Serial IO Drivers Version 30.100.2417.30 (station-drivers.com)
Use the device manager, using the .inf file
 you need three files namely
ialpss2_i2c_adl.cat
iaLPSS2_I2C_ADL.inf
iaLPSS2_I2C_ADL.sys
after that restart windows
Varadharajan K
Mike_Intel
Hello JimBillows,
Thank you for the quick reply.
We do support the software, however please also understand that since it is a web base application, there are a lot of uncontrollable factors that can affect it.
We have this documented link about the error that you encounter. Please try to open the link and follow the steps.
https://www.intel.com/content/www/us/en/support/articles/000026895/software/software-applications.html
Michael L.
MrZed
BIOS setting  under Chipset menu IOAPIC 24-119 must be enabled. Then install latest Intel chipset drivers, ME, MEI and last one Intel IO serial.
