16969 Discussions
Intel Driver & Support Assistant: check for new drivers error
true_12345
When Intel Driver & Support Assistant checks for new drivers, the webpage brings up the message "Sorry, something went wrong while trying to scan."  I ran the repair option from the installation program, which did not solve the problem, and then I uninstalled and reinstalled the program/app, but I still received this message.  Does someone know why I am receiving this message?  Thank you.
Update 10/31/2023:  This seems to only be an issue when using the Brave browser:  the scan completes when using the Microsoft Edge browser.  Also, the little green circle graphic on the Intel Diver & Support Assistant icon that is in the system tray is present, which was not present a day before.
Jocelyn_Intel
Hello, @benchi
Thank you for posting on the Intel® communities.
If I may jump into the conversation, these are some steps you can follow to try to fix this issue. However, what Mr. Alhill mentioned is a very important point to consider and is one of the steps. Please make sure you are using supported web browsers when trying to run Intel® DSA as part of the good operation of this tool:
Intel® Driver & Support Assistant (Intel® DSA) Results in “Sorry, Something Went Wrong While Trying to Scan” or Endless Scan
It is worth mentioning that Intel® DSA was designed for Intel systems such as the Intel® NUCs. We always recommend using your System Manufacturer's assistant tools to avoid incompatibility issues.
Jocelyn M.
Jocelyn_Intel
Hello, @true_12345
In order to assist you, what is the Intel product you are trying to update?
Is your system an Intel® NUC? Or is it a laptop/Desktop?
Jocelyn M.
true_12345
@Jocelyn_Intel :
I am attempting to run the Intel Driver & Support Assistant app to have it check for new drivers.  I have it on my laptop, which has an Intel CORE i5 7th Gen processor.
AlHill
@true_12345   DSA, in its wisdom, only supports Chrome, Edge, and Firefox.   BRAVE is not supported.
true_12345
@AlHill :
DSA worked previously on the Brave web browser; it has only been recently, in the past few days, that it has not worked.  I did recently update the Brave web browser to its latest version, so perhaps that caused a problem with DSA using it to check for updates.
AlHill
@true_12345   I am just the messenger.
Check https://www.intel.com/content/www/us/en/support/articles/000023000/software/software-applications.html under the paragraph "What Web Browsers Does Intel® DSA Support? "
true_12345
@AlHill :
Thanks for the link to the article.  The Brave update to version 1.59.124 may be what caused the problem.
Jocelyn_Intel
Hello, @benchi
Jocelyn M.
true_12345
@Jocelyn_Intel :
Thank you for the link to the online article.  I went through the possible resolutions by:  ensuring both services were running (they were); clearing the cache in the Brave web browser; restarting both services; uninstalling and reinstalling the tool; and, lastly, disabling Brave Shields.  When I toggle between enabling and disabling Brave Shields, the DSA scan goes from being dysfunctional to being functional.
Jocelyn_Intel
Hello, @true_12345
Thank you for your reply.
I am glad that you found a workaround for this issue in Brave, however, as previously mentioned, this is a not supported browser by Intel DSA, so if the issue persists, we recommend you use one of the supported browsers by Intel DSA to ensure its good operation, as it was designed to work with these browsers and cannot guarantee other browsers will work as expected.
If there's is another subject I can help you with, please let me know.
Jocelyn M.
Jocelyn_Intel
Hello, @true_12345
I hope you are doing great.
As we have not heard back from you, we will proceed to close this thread now.
If you need any further assistance, please feel free to contact us back and submit a new question as this thread will no longer be monitored.
Jocelyn M.
