Hi everyone,
I hope I found the right forum for my Problem.
I just bought a new Core Ultra 7 265K (+Mainboard and so on I listed everything down below) and it just keeps crashing on me (BSOD).
I kinda isolated the Problem to the Intel Innovation Platform Framework Processor Participant Driver, which is always mentioned in my Windows Error Logs as "failed to load \Driver\WUDFRd" and then the ID of the Innovation Platform Driver.
Everything I tried so far:
reinstalling Windows for the 3rd time now
reinstalling all my drivers (from Gigabyte and Intel)
disabling integrated graphics ( i heard it can be an issue with an pci gpu)
swapping the RAM sticks
disabling High Bandwidth and Low Latency in BIOS
putting RAM in Gear 2
disabling Intel Virtualization
disabling VT-d
and reinstalling windows again after I turned off all these settings
and frankly, I am now at a loss. I always thought of myself as pretty tech savy, but I can't seem to figure out my Problem.
I uploaded 3 of my Windows Dump Files, if you are asking for more I could put them somewhere too.
https://drive.google.com/drive/folders/1j7KgfVBq_UThTGQV7NBqGKrynJVt7YW9?usp=sharing
In this Image you can see all the warnings from the Intel Innovation Driver (I filtered them so it is only showing Errors related to this Driver) but not all of them Result in a BSOD.
My current Setup:
Intel Core Ultra 7 265K
Gigabyte Z890 Gaming Wifi7
Gskill TridentZ 8000MT/s (F5-8000J4048F24GX2-TZ5K - Supported by my Mainboard and Intel 200s Boost)
Samsung 990 Pro 2TB
Asus Tuf Gaming RTX 3080
I am really hoping that anyone of you guys can help me solve my Problem.
If you have more questions regarding my bluescreens or setup dont hesitate to ask.
Thanks for the Help
Hello MkN_,
Based on our internal review, it appears that the crashing issues you previously experienced are no longer occurring. Regarding the VEN_8086 error, this code refers to Intel Corporation’s Vendor ID in the PCI (Peripheral Component Interconnect) system, which includes components such as the chipset, integrated graphics, network, audio, USB, storage controllers, and CPU-related devices.
Since the error seems to point toward the PCI port and your 990 Pro SSD, it’s likely that the SSD may be contributing to the issue. As you mentioned, you plan to contact your retailer for a possible SSD replacement that’s a good next step. If the issue continues even after replacement, it may indicate a motherboard PCIe port problem, and we recommend reaching out to your motherboard manufacturer (OEM) for further assistance.
There’s no need to provide an SSU report at this time, as your inquiry was mainly to verify whether the issue is Intel-related. Additionally, based on our review, your voltage readings are within normal and expected limits for your processor.
With that, we recommend contacting your place of purchase or the OEM for further diagnosis and resolution of this concern.
Thank you for your understanding and cooperation. I'll proceed with closing this thread. have a great day!!
John M.
链接已复制
Hello MkN_,
Thank you for reaching out to us and sharing the detailed information about your issue. I understand how frustrating it must be to experience repeated system crashes, especially after reinstalling Windows and performing several troubleshooting steps on your own. I truly appreciate the effort you’ve already taken to isolate the problem.
Based on the information provided, the issue appears to be related to the Intel® Innovation Platform Framework (IPF) Processor Participant Driver, as noted in your Windows Event Logs. Let’s go through a few steps to help us isolate and address this further.
First, make sure you have tried to install Intel® IPF through Download Center link, as indicated in below message box. If you continue to receive below XTU message regarding Intel® IPF, only then proceed to uninstall existing versions of Intel® IPF.
There are two options to uninstall Intel® IPF:
- Option 1
- Check if Intel® IPF is already installed on your device.
- Right click on Windows start button and select Device Manager.
- Check if Intel® Innovation Platform Framework components are present under System Devices.
- If Intel® IPF is installed, you need to uninstall it. In Device Manager window:
- Right click on the components listed and select Uninstall Device.
- When the Uninstall Device window appears, make sure to select the checkbox for Attempt to remove the driver for this device, and then click on the Uninstall button.
- It’s time to install the new driver version. Download latest Intel® IPF installer from Intel Download Center.
- If Intel® IPF message continues to pop-up, proceed to Option 2 below.
Option 2
- Find Command Prompt through Windows* search, right click and Run as administrator.
- Run the following command to list the drivers installed on the system: pnputil /enum-drivers.
- Parse the installed driver list and find the “Published Name” mapped to the Original Name “ipf_cpu.inf”
- Run the following command to delete the Intel® Innovation Platform Framework Processor Participant: pnputil /delete-driver <published name for ipf_cpu.inf> /uninstall
- Referencing the example below, the command would be: pnputil /delete-driver oem52.inf /uninstall
- Parse the installed driver list and find the “Published Name” mapped to the Original Name “ipf_acpi.inf”
- Run the following command to delete the Intel® Innovation Platform Framework Processor Participant: pnputil /delete-driver <published name for ipf_acpi.inf> /uninstall
- Referencing the example below, the command would be: pnputil /delete-driver oem39.inf /uninstall
- Once the device is uninstalled, restart system.
Additionally, if the issue persists, please provide the following information:
- Windows version
- Screenshot of the Device Manager
- When did the issue start occurring?
- Were there any recent changes made to the system?
John M.
thanks for your fast answer.
I currently rolled back my windows install to windows 10 in a last ditch effort to see if the issue is in some kind related to windows 11.
I am going on vacation next week but after that I will try your solution.
Do you have a direct link to the Intel IPF Installer from your website? I googled it and couldn't find anything except from Dell and HP.
I just got my 265k a month ago and the bluescreens started about 2 weeks after I got it.
Before that I had an i7 7700k, some ddr4 3000 RAM and an Asus Board. Only thing that has remained the same is my rtx 3080.
I will post my Windows Version and Device manager If im encountering anymore problems after i roll back to windows 11.
Thanks for your effort.
Hello MkN_,
Thank you for the update, and I appreciate you taking the time to share the steps you’ve tried so far. It’s good to hear that you’re testing with Windows 10 to help determine whether the issue is related to Windows 11.
Regarding your question, the Intel® IPF Installer isn’t directly available for download from our website as it’s typically distributed through system or motherboard manufacturers. However, once you’re back from your vacation, I can help check whether there’s a compatible version available for your specific configuration and provide guidance on obtaining it safely.
For now, please go ahead with your current setup and enjoy your vacation. Once you return and if the issue persists after rolling back to Windows 11, kindly share your Windows version, Device Manager details, and any recent blue screen error codes so we can continue troubleshooting.
Thank you again for your cooperation and patience we’ll make sure to help you get this resolved.
John M.
Hello MkN_,
John M.
Hi John,
thank you for your follow up question, I didnt have much time now to troubleshoot my system any further.
The things I can say right now are, I upgraded to Windows 11 Pro 25H2 (updated just right now) build 26200.6899.
I am sorry but I dont really know to what you are referring to with your question about my device manager details.
I noted my last error codes (Win10 and Win11):
Win10:
Page Fault In Non Paged Area
KMode Exception Not Handled
Win11:
System Service Exception
The last Win11 error code I got after I threw my Arc B580 into my build in a last hope effort to see if it could be something between my new cpu and my rtx 3080, so it could be and arc related bluescreen. I unfortunatly didnt save the dumps, because I switched so fast between the Windows versions to uninstall my graphics drivers.
And I gotta say, the Core Ultra 7 is a really nice and fast chip in order to do that, if there werent these **bleep** crashes.
I think I found the driver package where the Intel IPF driver is located on Gigabytes website. On (https://www.gigabyte.com/Motherboard/Z890-GAMING-X-WIFI7/support#dl) it should be the first chipset driver called Intel DTT (APO) I think.
I reinstalled all of them now again to see if it makes any difference.
As a sidenote, after I setup windows 11 again I tried installing all the chipset drivers and on all of the listed ones I got a "This program might not have installed correctly" popup (I attached some screenshots but they are in german). After restarting and installing them for a second time this popup didnt show anymore and I think the installation got through.
Thank you for waiting a bit for my response.
Hello MkN_,
Thank you for the update, and I apologize for the confusion earlier regarding the Device Manager details. What I meant was that I’d like to request a screenshot of your Device Manager so I can check if there are any yellow bang errors that may need to be addressed.
Additionally, we need to properly isolate the issue to help identify the root cause. Please perform the following steps when you have time:
Test the system without a graphics card.
- Use only the processor’s integrated graphics to check if the issue persists. This will help us determine if the instability is related to the processor or the discrete GPU.
Test again with the graphics card installed.
- When testing with the GPU, try using a different PCIe slot if available to verify whether the issue might be related to the PCIe slot or the graphics card connection.
Lastly, please follow the steps outlined in the article Troubleshooting Tips for Blue Screen Error (BSOD) While Using Intel® Processors to further isolate the BSOD issue.
Once you’ve completed the steps above, kindly provide an update with your findings and the requested screenshot.
Thank you for your time and cooperation.
John M.
Hi MkN_,
John is currently away and I'll be temporarily handle the thread. I'm just following up about the recommendations that was previously shared to you. Have you had the chance to try it out? If you continue to encounter the issue, please let us know.
Jed G.
Hi Jed,
sorry for my late reply, had a lot to do at work and university.
Thank you for handling this matter now.
I am currently not at home so I cant send you a screenshot from my Device Manager but I can assure you that there are all drivers installed and no yellow warning signs are shown.
My system did not crash in the last week, so I am carefully positive that somehow I got it fixed.
The things i did were:
-Changing my PSU (which could have been the solution, but I stress tested my system extensively before and it did not crash any more frequently than usual, so I am not exactly sure)
-Updating to Windows 25H2 (which could have fixed some driver issues)
-Playing with my ASPM settings in my Bios (I dont think that solved the issue, but maybe)
I will continue monitoring my system in the following week and report any more crashes back to you.
Hopefully my issue is resolved now, even if I dont exactly know why.
Thanks for your service and thanks to John for keeping in touch with me in the first place.
Just a little question on the back note, how high is the voltage normally in the idle state for the 265K? I previously had a 7700K and it had a much lower idle voltage. Just checking because I heard about problems with the high idle voltage on the 13th and 14th gen intel processor which led to degredation issues.
Thanks, and have a nice weekend.
Hi MkN_,
Thank you for the update, and no worries about the delay I completely understand how busy things can get with work and university. I really appreciate you taking the time to share the details of what you’ve done so far.
It’s great to hear that your system has been stable over the past week. The steps you took especially replacing the PSU and updating to Windows 25H2 could indeed have addressed underlying power or compatibility issues. Keeping an eye on your system’s performance in the coming days is a good approach, and I’d appreciate it if you could let us know should the issue return.
Regarding your question about CPU idle voltage for the Intel® Core™ Ultra 7 Processor 265KK:
- It’s normal for modern Intel® processors (including 12th, 13th, and 14th Gen) to show higher idle voltages compared to older generations.
- The voltage can fluctuate dynamically often between 1.0V and 1.4V depending on background tasks, power management settings, and motherboard BIOS behavior.
- These voltage spikes at idle are expected and generally do not indicate degradation or instability, as the current draw at idle is very low.
If you’d like, you can also monitor your CPU voltage and temperatures using Intel® Extreme Tuning Utility (XTU) or your motherboard’s monitoring software to confirm that everything stays within safe operating limits.
I’m glad things are looking better now and thank you again for your patience and cooperation throughout this process.
John M.
Hi John,
glad to hear that you're back again.
Unfortunately I have some bad news, but I am not exactly sure if the issue is conntected to Intel.
This Week I started to experience some issues, my audio was cutting out and then the whole System started to lag or feel like really really sluggish. Sometimes its was still kind of usable but sometimes it bricked itself and I couldnt do anything anymore. Surprisingly all without a single blueescreen.
Five Screenshots show some warnings and some errors related to my 990Pro SSD.
On one of them there is a connection to an Intel Device (VEN_8086 is Intels Vendor ID) and it says something like "There was a corrected Hardware failure in a PCI Port"
I think it is just a faulty PCIE SSD and I will contact my retailer to get it replaced, but I just wanted to make sure that there isn't something else with this error message that you know about.
Except for these recent events I did not experience any bluescreens or anything related to my previously asked problem.
If you need help translating some of these errors, I am happy to help.
Thank you for your assistance so far.
And thank you for your explanation regarding the CPU Voltage.
I was just wondering because I saw my CPU hovering at around 1,4v constantly and it was a bit high for my taste. But it turned out that I just forgot to turn "high performance" to "balanced" in my Control Panel and now my Vcore is hovering at around 0,9v-1,1v and my core voltages are at 0,7v to 1,0v at idle.
Hello MkN_,
Thank you for providing the screenshots, they are helpful for our investigation. For now, please allow me some time to properly investigate this internally in our lab to review and verify all possible concerns.
Once I’ve completed the internal investigation, I’ll get back to you with an update.
To further assist you, I kindly request that you download and execute the Intel System Support Utility (SSU) in order to provide me with a complete system specification, which will enable me to assist you in reviewing your system information.
When the download is complete, launch SSU.exe.
1. Scan: Check the box Everything.
2. Click Scan.
3. Review: When finished scanning, click Next.
4. Click Save.
John M.
Hello MkN_,
John M.
Hi John,
thank you for your detailed answer.
I've contacted my retailer and I am expecting an answer soon.
If swapping the Motherboard or the SSD doesnt fix my problem and I have some crashes related to an 8086 Driver, I will open another ticket.
(Hopefully not) Until then, keep doing what you're doing and finally release the Arc B770 at an affordable price, so I can upgrade to something from my RTX 3080.
Have a nice week,
MkN
Hey MkN_,
I was wondering if you've had any progress with this issue? I am not experiencing any BSODs, but rather GPU crashes going to black screen, and I seem to be having the some of the same events in event viewer you shared, the "\Driver\WUDFRd failed to load." as well as gigabyte control center failures, nvidia overlay failures. I find it odd we have similar items : samsung 990 pro 2tb, and gigabyte Z boards.
Andrew
