16893 Discussions
Intel Management Engine Firmware - 10 (1803 or Later)/11 (21H2 or Later) -
Hambonebtc
I am using a Lenovo T14s ThinkPad and I have received notifications that the Intel Management Engine Firmware is in need of a update. I have tried numerous of times to update this but each time it fails. I have tried both automatic and manual update with no success. This is listed as a critical update. I recently updated the BIOS and I was hoping that would correct the issue. Please help!
I have attached the system report.
Thank you,
Jindal_Dhuri
I have Lenovo X360 Yoga 20NQS I also failed same firmware update I talked with OEM they told me it's a bug inside the firmware update so that it always failed to install they also told me wait for few weeks so after that a new firmware will release. #firmware #failed #lenovo #intel #microsoft I Hope intel or Lenovo will take this seriously and release a new firmware as soon as possible.
I tried Lenovo Vantage, Direct Download firmware file from OEM Site, use Intel Driver & support Assistance but all methods are not working. after rebooting system start normally .
Failed Firmware in LenovoFailed Firmware in Lenovo
Rangerdavid
I'm having the exact same problem.  Even my IT guy tried and couldn't get it to install.  He backpedaled and said he installed a newer version, but there isn't a newer version.  Did you ever get a fix for this?
n_scott_pearson
You need to talk to the motherboard manufacturer, not Intel, about this issue. They are responsible for all firmware being installed onto their motherboard.
EricTravis
I too am having this problem. I have a Lenovo motherboard.
Yamila
Estoy usando un Lenovo T14s ThinkPad y he recibido notificaciones de que el Intel Management Engine Firmware-10 (1803 or Later)/ 11(21H2 or Later)-15.0.49.2573 necesita una actualización, pero cada vez que la intento actualizar me sale error en la instalación. He intentado muchas veces actualizar esto, pero cada vez falla arrojando error en la instalación. He probado tanto la actualización automática como la manual sin éxito. Esto se cataloga como una actualización crítica. Recientemente actualicé el BIOS Update Utility-10/11-1.60 y esperaba que se resolviera el problema, pero aún continúa saliendo error de instalación. Agradecería mucho su ayuda por favor.
Slds,
PC1997
I read the readme file for each version of the Intel Management Engine firmware listed in this thread, and none of the laptop models posted are on the compatibility list.
https://download.lenovo.com/pccbbs/mobiles/n2imd18w.txt
https://download.lenovo.com/pccbbs/mobiles/n32rg31w.html
You can try updating Windows to the latest feature update supported by your laptop and try again.
Leí el archivo README de cada versión del firmware de Intel Management Engine listado en este hilo, y ninguno de los modelos de laptops publicados está en la lista de compatibilidad.
Puedes intentar actualizar Windows a la última actualización de características compatible con tu laptop y volver a intentarlo.
Rangerdavid
Thank you for this information.
Roberto-53
I am using a Lenovo 280 ThinkPad Windows 10 64 bit  and I have received notifications that the Intel Management Engine Firmware is in need of a update. I have tried numerous of times to update this but each time it fails. I have tried both automatic and manual update with no success. This is listed as a critical update. I recently updated the BIOS and I was hoping that would correct the issue. Please help!
Roberto-53
the message received
"The FW Update Utility couldn't identify the system's SKU Consumer or Corporate Please Check your ME FW Update utility package and Try again"
pressed_for_time
Valued Contributor II
I can only repeat the advice already given by @n_scott_pearson that you need to raise this with Lenovo, its Technical Support department may be able to help. As an alternative there is the Lenovo Support Community that can be found here where you can ask a question.
