16889 Discussions
Intel Management Engine exclamation mark appear in the driver
Hass12
I have noticed there is a exclamation mark appearing next to the Intel Management Engine, upon taking a closer under the device Status, it basically say that it cannot veriy the digital signature for the driver,...might have installed a file that is signed incorrectly or damaged.
pressed_for_time
Valued Contributor II
The manufacturer of your motherboard will provide the latest Intel Management Engine driver and also the latest firmware. Try downloading and installing the latest versions of those from the support site for your board.
Hass12
Thank you, so I attempted to reinstall the driver from the source, but keep seeing the same message
Chris444
Can you please share hardware IDs? attached you will find a example picture
