16774 Discussions
Intel Q9505 64-bit support
Employé
3 063 Visites
Is this processor supporting the 64-bit instruction set? If I go here: http://ark.intel.com/Product.aspx?id=42920 http://ark.intel.com/Product.aspx?id=42920 the webiste says yes.
But if I compare some products, http://ark.intel.com/Compare.aspx?ids=38512,42920,33924, http://ark.intel.com/Compare.aspx?ids=38512,42920,33924,, the Instruction Set field is unfilled for this CPU.
I ask this, because i'm having problems installing VMWare ESX 4 on a PC having this CPU... Might the problem come from here?
Levente Rog
0 Compliments
2 Réponses
Employé
1 793 Visites
You can try this tool as well. I just got it from PeterUk.
http://www.grc.com/securable.htm
Kind Regards,
Aryan.
0 Compliments
Répondre
