16865 Discussions
Intel QX9650 Support Windows 10?
PPini2
Hello, i want to know if the Intel QX9650 support windows 10!
AP16
Valued Contributor III
Yorkfield CPUs supports cmpxchg16b instruction, but many MBs of that era had errors in BIOS, preventing instruction to work, so update BIOS first, if possible.
Cesar_B_Intel
Hello MsPro
As Al_Hill and JFFulcrum mentioned above, the processor supports the instructions for Windows* 10, however, the processor is not the only component on your computer which determines whether it Supports windows 10 or not. Depending on your motherboard a BIOS update may be required.
Please confirm your computer's configuration in order to have a better understanding of your system capabilities and possible compatibility with Windows 10*
You may try this update (Microsoft's Tool) to check you system compatibility for Windows 10* before you install it:https://support.microsoft.com/en-us/kb/3035583 https://support.microsoft.com/en-us/kb/3035583
You may get more information here http://windows.microsoft.com/en-us/windows-10/compatibility-report-windows-10 Compatibility report for Windows 10: FAQ - Windows Help
Caesar B.
*Other names and brands may be claimed as the property of others.
