16769 Discussions
Intel Thermal Solution TS13X
Can the intel thermal solutions TS13x CPU cooler be used in computers aboard an aircraft that is pressurized? are there any known limitations on these liquid coolers being used at altitude ?
IUman
Hello CharlesMcC,
In this case I will need to escalate your question to give you a good answer.
As soon as I get an answer I will post it here.
I will appreciate your patience and hopefully I will get an answer soon.
Thanks you,
Ronny_G_Intel
Hi CharlesMcC,
I am investigating and will get back to you as soon as possible.
