16766 Discussions
Intel XTU/BIOS - aktuelle Werte mit PowerShell auslesen (z.B. CPU Voltage Offset)
johannCH
mit einem PowerShell Script und der Intel XTU ProfilesApi.dll aktiviere ich beim Start-up ein mit dem Intel XTU GUI definiertes Profile. Wie kann ich nun via PowerShell die aktuellen Werte abfragen?
AlHill
What is your processor model number?
Doc
johannCH
Lenovo X1 Extreme Gen. 2
CPU: Intel Core i7-9750H CPU @ 2.60GHz
Intel XTU v6.5.1.360
i will only set CPU Voltage Offset -0.125V...
johann
AlHill
XTU is not supported on your processor. XTU only supports X and K processors, and you have an H processor.
Doc
johannCH
thank's for the hint.
but Intel XTU seems to work with my procesor for adjusting CPU Voltage Offset?
to be shure, i have to read out the value from BIOS, as i asked in the thread.
johann
AdrianM_Intel
Hello johannCH,
Thank you for posting on the Intel® communities.
The Intel Core i7-9750H Processor (12M Cache, up to 4.50 GHz) is not on the list of valid products for Intel Extreme Tuning Utility - Intel XTU since this tool is intended for Intel unlocked processor (K and X). For this reason, the available features in Intel XTU might be limited on your system.
Bear in mind that altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components.
Adrian M.
