16785 Discussions
Intel XTU issue - the platform does not support overclocking 13900k
KMaksoncheCK
There is a problem with overclock i9 13900k with XTU(7.13.0.38) on Windows 11 Version 22H2 for x64-based Systems (KB5030310) and lastest  bios version(trying all version since v2). All fields are locked.
 Hoping to get any answer to find way to solve the problem, thanks in advance!
IsaacQ_Intel
Hello KmaksoncheCK
SSU: Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
This document will be necessary to check your entire system, in order to find possible errors or incompatibilities.
Also, based on this article, please check the Product Features and Requirements for Intel® Extreme Tuning Utility.
Note: In order to get full access to CPU and memory controls, your motherboard BIOS should support altering of CPU and/or RAM values (usually applicable for Z- or X- chipsets). To get more info for supported controls contact your motherboard's manufacturer.
For more information, check this article: Common Issues and Resolutions for Intel® Extreme Tuning Utility
Isaac Q.
IsaacQ_Intel
Dear KMaksoncheCK,
We trust that you're doing well.
Have you had the chance to review our previous post?
Could you kindly provide us with the SSU? Additionally, we kindly request you to inspect the Product Features and Requirements for the Intel® Extreme Tuning Utility as per the attached article.
Please be aware that to fully access CPU and memory controls, your motherboard BIOS must support adjustments to CPU and/or RAM values. This is typically applicable to Z- or X- chipsets. If you require further details about supported controls, we recommend contacting your motherboard's manufacturer.
For more in-depth information, please consult the following article: "Common Issues and Resolutions for Intel® Extreme Tuning Utility."
If you still require assistance, please don't hesitate to reach out. Otherwise, we will proceed to close this thread.
Warm regards,
Isaac Q.
KMaksoncheCK
Hello IsaacQ!
Thank you for your answer! My motherboard BIOS support adjustments to CPU and/or RAM values. I attach system info file for diagnostic to find possible problem, thanks in advance!
IsaacQ_Intel
Dear @KMaksoncheCK,
I wanted to express our gratitude for your prompt response. Your provided information is invaluable to us. We are now in the process of investigating the issue internally and will return with comprehensive details shortly.
Warm regards,
Isaac Q.
IsaacQ_Intel
Dear @KMaksoncheCK,
Based on our investigation, please try the troubleshooting steps in this article:
·      Advanced Tuning Settings Are Grayed Out on Intel® XTU with Intel® Core™ Processors K- and X-Series
Warm regards,
Isaac Q.
IsaacQ_Intel
Hello KMaksoncheCK
We hope you are doing fine.
Please try the troubleshooting steps in this article:
Isaac Q.
IsaacQ_Intel
Hello KMaksoncheCK
Best regards.
Isaac Q.
