17248 Discussions
Intel computer stick STCK1A32WFC
Nafu
Hello, I am looking for a SOC, Intel HD graphics driver for Intel computer stick STCK1A32WFC. On the Intel website, the links to the drivers are not active, and the Intel Drive Support Assistant program displays a message that no drivers are supported. Windows 10 has installed all the drivers from Windows Update, (no uninstalled drivers in the device manager) but the sound does not work, there is no Intel HD driver and the SD card reader does not work.
ssybesma
Intel got nasty about this and removed all the 1st gen ICS drivers. Bad customer service. I have the same issue as you as far as needing drivers.
UPDATE: I just found the folder I saved with all the last versions of the 1st gen ICS drivers and BIOS...let me know how I can contact you and I'll send you a ZIP file. I plan to share them on Archive.org later on. They cover all models of the 1st gen ICS that Intel deleted the drivers and BIOS for.
Erv
Can i also have the sip. File folder, my sdcard & bluetooth connectivity dont work now after updates
AlHill
Look here:
https://web.archive.org/web/20231206112038/https://www.intel.com/content/www/us/en/products/sku/86612/intel-compute-stick-stck1a32wfc/downloads.html
[CoPilot is a virus, W11 is a keystroke logger, all from MicroSlop]
neato404
Hello, I have a stk1AW32SC model and after a reinstallation I can no longer find the plugins, and the audio no longer works. Can you send me your file please?
n_scott_pearson
What I have you'll find it in my share (here). See subfolder STK1AW32SC. It's way too big to send my email.
neato404
Hello, thank you for your reply. I have tried all the drivers, but unfortunately it does not work. Windows only gives an error message every time. My Compute Stick has an Intel Atom x5 Z8330 processor and it seems that this is not compatible with it.
AlHill
Using the wayback machine, you will find all necessary drivers, including the SOC driver.
[AI is the same as snake-oil]
neato404
Hello, thank you for I just downloaded the driver "Intel® HD Graphics Driver for STCK1A32WFC" but I still get the following error message: "this system does not meet the minimum system requirements for software installation"
AlHill
Install the SOC driver first.
neato404
I found the correct page in "wayback" for me: https://web.archive.org/web/20230928085854/https://www.intel.com/content/www/us/en/products/sku/91065/intel-compute-stick-stk1aw32sc/downloads.html
And I downloaded: "System-on-a-Chip (SoC) Driver Package for STK1AW32SC" but I get the following error message: "The setup program ended prematurely due to the following error: [String ID not found]"
I looked at the log file:
4:20:17:767:   Core version: 2.0.5
14:20:17:767:   Setup version: 2.0.0.6
14:20:17:783:   Command line: "C:\Users\computer\Desktop\sc_win10_32_drivers_07252016 (1)\Setup.exe"
14:20:17:783:   OS data: 6-2-1-0 32-bit
14:20:17:783:   System up time: 3430 sec
14:20:17:783:   Current UI language: 040C
14:20:17:783:   Language folder: C:\Users\computer\AppData\Local\Temp\IIF59FA.tmp
14:20:17:908:     Found C:\Users\computer\AppData\Local\Temp\IIF59FA.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 1
14:20:17:923:   Relaunching setup as elevated
14:20:21:829:   Dumping MSI properties (0 total)
14:20:21:829:   Exit code: 0
14:20:21:829:   >>> Log End
14:20:21:922:   >>> Log start
14:20:21:922:   Core version: 2.0.5
14:20:21:922:   Setup version: 2.0.0.6
14:20:21:922:   Command line: "C:\Users\computer\Desktop\sc_win10_32_drivers_07252016 (1)\Setup.exe"
14:20:21:922:   OS data: 6-2-1-0 32-bit
14:20:21:938:   System up time: 3435 sec
14:20:21:938:   Current UI language: 040C
14:20:21:938:   Language folder: C:\Users\computer\AppData\Local\Temp\IIF6A26.tmp
14:20:22:063:     Found C:\Users\computer\AppData\Local\Temp\IIF6A26.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 1
14:20:22:079:   Package version: 1.1.1.1
14:20:22:079:   Installed version: <Not installed>
14:20:22:079:   This is a clean install
14:20:22:094:   Setup mode: Installation
14:20:22:094:   Looking for OS: 6.0
14:20:22:094:   OS check passed
14:20:22:094:   .NET not required, skipping requirement check
14:20:22:094:   Driver source is C:\Users\computer\Desktop\sc_win10_32_drivers_07252016 (1)\Drivers
14:20:22:094:   Using folder 'C:\Users\computer\Desktop\sc_win10_32_drivers_07252016 (1)\Drivers' as the driver source
14:20:22:094:   Scanning all active devices
14:20:22:157: E Win32 exception occurred!!
14:20:22:157:     Error code: 0xE0000100 (-536870656)
14:20:22:157:     Error text: ''
14:20:22:157:     Extended error text: ''
14:20:22:157:     Debug info: 'INF.cpp (12)'
14:20:22:204:   Showing dialog: FINISH
14:34:16:080:   Dumping MSI properties (0 total)
14:34:16:096:   Exit code: 1602
AlHill
I am confused.  Your post said FC, but now you are using SC?  Which stick do you really have?
And, earlier you said you tried all the drivers from Scott's download.  That is not possible as some were not for your stick.
So, which stick do you have?  And, now with the drivers being found on the wayback machine, I suggest you start with a clean install.
Also, I had an FC stick, and the drivers and W10 worked as they should.  Installing that SOC driver first is important.
neato404
I have a Compute Stick stk1aw32sc.
Scott added a folder "stk1aw32sc" to his share.
I had to reinstall Windows 10 on this machine; unfortunately, I hadn't saved the drivers.
Since then, the audio hasn't worked, and I realized that this was because the HD Graphics Driver wasn't installed. But I don't understand why I'm getting all these error messages.
AlHill
Ok, I misread using the title of this post, which is why you should have created a new post for yourself.
You have found the SC drivers on the wayback machine.  Post the link so others can find them as well.
Now, are you trying to install 32-bit or 64-bit Windows 10?  Hopefully, you are using 32-bit windows 10.
Now, download and save the SOC driver for your SC stick.  Do a fresh install of 32-bit windows 10.  Then, install the SOC driver before you do anything else.  Then report back.
neato404
UPDATE : Okay, I managed to manually update the graphics card driver using the Device Manager, and miraculously everything works ^_^
I just reinstalled Windows 10 21-h-1 32-bit.
I disabled Wi-Fi so I wouldn't have Windows updates at startup.
I launched the SoC driver installation and still got the error: "The setup program ended prematurely due to the following error: [String ID not found]."
I also tried the HD Graphics drivers afterward, but without success. However, the Bluetooth and Wi-Fi drivers installed perfectly without any errors.
n_scott_pearson
The first Intel thing that you should install is the Chipset Device Software package specific to your stick. This contains all of the INF files that configure many of the Windows-provided Intel drivers. It is also the springboard for many of the other Intel installer packages.
The second thing you should install is the Intel Management Engine package specific to your stick.
The third thing you should install is the SOC driver package specific to your stick.
In fact, this is what you should do in *any* Intel-based PC installation.
Hope this helps,
n_scott_pearson
While I am at it, let's be specific. I was asked to provide the files I had for the FC ICS. I was not asked to provide any files for the SC ICS and you should not be using them. The SC ICS is a generation newer than the FC ICS.
The real problem here is friggin lazy people asking for the drivers for one thing within a conversation for another. Same with those asking about their problem within the conversation for someone else's problem. Stop doing this dammit! If you need something different than what the conversation is about, create your own conversation using the Post a Question button on the forum's main page.
OMT
I just wanted to thank all the responders to this post, as I _had_ the same problem with my  STCK1A32WFC as the original poster. After reading the whole of the responses, the cure for my  STCK1A32WFC was downloading and installing the SOC. It seems to have returned the stick to normal without further downloads. It has taught me to save a file containing all these Legacy files, ,exes, drivers, and links so when the next time happens I will not have the same long search for a solution. Thank you all.
