16955 Discussions
Intel i3 1005 G1 Turbo Boost Option
StephSkyy
I would like to know if my i3 1005 G1 10th generation processor supports Turbo Boost. It is written on the Intel site as well as HP site. I tried to enable these options in Bios but found no option. There are no processor options and no option to enable Turbo Boost.
Is the i3 1005G1 is supposed to be equipped with Intel® Turbo Boost and Intel® Hyper-Threading Technologies
. It is clearly written on intel site that my cpu has 1.20ghz base frequency and 3.4ghz with Turbo Boost.
Can you help me with this issue.
I have attached some files with informations that might help you.
Thank. You.
AndrewG_Intel
Hello @StephSkyy
We found another thread describing the same inquiry and the same hardware/software environment as this one. In order to avoid duplication of effort, we will close this thread now and the support will continue through your first thread here: Intel i3 1005 G1 Turbo Boost Option
Andrew G.
